So, your room is 30c+??? If so, then those temps i would think are in the balllark..
Those are a bear to mount properly. If you try to remount, make sure you clean the paste off and apply new.
Your gaming temps are 70c? Still seems high for stock and 26c max ambient. You likely wont be able to run most stress tests...
Every cpu is different indeed, id jjst expect better temps
Sure yoyr fans are vlowing the way you said? Front/sides = intake, top/rear exhaust. Where did you mount the cooler?
The clock speeds you stated are correct for intel Turbo Boost.
Thanks for clarifying. I understand that processors don't go to exactly 4200mhz. But is it normal for one single core to be less boosted than the others?
Those temps are still surprisingly high but certainly not dangerous. I'm thinking your CPU is a great candidate for delidding and replacing the stock gunky TIM under the lid with liquid metal TIM. You would likely see a 10-20 celcius degree drop in load temps.
If you delid the processor it voids the 3 year Intel warranty. I would not do it my self also your temperature is in the normal operation range.
I still want to do some stress testing to make sure it is stable in the long run. What is the recommended software for me. So far I have only ran cpuz stress test. I want toto get an idea of my temperature range
