Did you make sure the all connectors are seated well? Unplug and reseat them? Perhaps you did when you said you went over the whole motherboard.i think its booting normally.(not positive) i have no beep codes. i also tested that by taking out ram to get a beep. tested the CPU in a different mobo. It stopped working after he shut it down .. went to turn it back on and no go.
Is this a newly installed board?
Did you test it outside the case?i am having this issue. New system. No beep, but there is light/power/fan
