- Dec 4, 2011
Dear community,
Recently I switched to Intel after long run with unlocked AMD. Even replaced Radeon HD7850 with ASUS 1050 Ti OC 4GB and finally got rid of all AMD components. I am now proud owner of i5-4690K and ROG MAXIMUS VI HERO. I have few questions about my temperature sensors, so maybe MAXIMUS guru can help (i searched ROG community forums for answers but no luck):
I am running overclocked CPU @ 4.4GHz with 1.200V (100x44) and (Cache 100x41 with 1.166V). CPU is cooled with Cooler Master Hyper 212 Plus with dual 120mm PWM fans: CM Fan (higher CFM) for push and LC Power (lower CFM) for pull in case which is filled with 5 additional 120mm Fans, 2 running from molex and 3 controlled by MOBO, slightly negative pressurized.
The Rig seems stable and cool for most of the time, very rarely CPU hitting 70°C (only under heavy benchmark and standard fan speed profiles). I would like to know what are all these temperature sensors in MAXIMUS VI HERO reported by OpenHardwareMonitor (see screenshot).
Thanks in advance
Thanks in advance
