From a little research.
A way to cure this problem, from reads along the way, multiple cures.
Interesting info gathered::
The message is supposed to be generated if there is a short on a +5vdc USB power trace
The Maximus Formula's USB controller is in the ICH9R chip
Gives you an idea of possible bad parts... caps with issues perhaps?
I had the same problem. But I managed to fix it. All i had to do was open up the computer and remove a fan and the power block and disconnected the front usb port. it took a while but it work. Hopes this helps
Not sure what he means by power block, but interesting a Fan was too much draw perhaps a bad 12/5 v rail? But less hardware made this issue gone.
1
Clear cmos. Always do this the long way. Jumper psu and batter all disconnected or unplugged.
2.
Change Ram slots or remove Ram.
3. Look for bent pins in the USB ports or damage to USB ports that may be repairable.
4.
PSU was bad. Board gives random overvolt or undercurrent and surge along with USB errors.
5.
Board was defective or faulty caps. It happens......
6.
The problem turned out to be a lead coming from an add on multi function bay. It had two USB flying leads, one of which was the standard block with 5 socket holes on one side and four on the other so that it could only be fitted in one way around.
7.
Bad mounting PCB to case, screws too tight, fallen screw caught on back of PCB between board and case causing a short.
In short and lastly, I would question the Alpine PSU and give it a quick test. A multimeter will help.
