Hi, this is a lovely place. I'm not as heavy into this stuff as I used to be, and I find myself researching well beyond my means and need a bit of advice.
I had settled on the gskill DDR4 2x16 3200 RGB chips, but in reading some of the posts about mild OC and normal speeds and such (I'm a bit dense in most of these things) it seems this is "the chip" to go with, but I just need quick advice.
Is it worth the extra $50 to get the 3200 14cas chips, or stick with the 3000 14cas chips? I know, it's only $50 (which is minimal in considering cost of a complete PC build), but from all that I'm reading on here, I can't tell if it will be worth it, or if i can mildly bump up the 3000 just as easily as the 3200?
So talk to me like I'm a child, and tell me which one I should opt for This is primarily for gaming and live streaming. I won't be pushing this beast up to 5ghz or anything, i might bump up the speed just a tad, but nothing too crazy. I am just stuck reading so many reviews and comparisons on RAM, and at least in this forum, the G.Skill - Trident Z RGB 32GB (2 x 16GB) DDR4-3200 Memory seems to have a very high recommendation. But, if i can save $50 and stick with the 3000mhz, I'll do that. Otherwise, if the 3200 is worth the cost, that was what I was going to get anyway.
Thanks!
this will be going in:
Intel - Core i7-8700K 3.7GHz 6-Core Processor
Asus - ROG MAXIMUS X CODE ATX LGA1151 Motherboard
Thermalright - Le Grand Macho RT 73.6 CFM CPU Cooler
Fractal Design - Define R6 Gunmetal TG ATX Mid Tower Case
EVGA - SuperNOVA G3 850W 80+ Gold Certified Fully-Modular ATX Power Supply
Thanks!
