- May 20, 2002
- Champaign, IL, USA
Now I just received my P4T533-C. I thought someone might be interested in the differences between them in terms of OC.
Here is what I found:
(1)Voltage:
P4T-E Vcore normally lower than BIOS setting for about 0.05v.
P4T533-C Vcore is a little bit higher than BIOS setting. for about 0.02v.
(2)DDRG chips:
My P4T-E has the SAME DDRG chips as P4T533-C, which is ICS xxx-13.
(3) BIOS FSB settings:
P4T-E has max 133MHz FSB in BIOS, while P4T533-C max 150Mhz.
(4) on board audio:
P4T-E onboard audio will not work if overclokc to 133FSB in BIOS.
Audio will work in Jumper mode. P4T533C does not have this problem.
(5) MoBo temperature:
P4T533-C seems running a little hotter than P4T-E.
(6) RDRAM default:
P4T-E default for PC800 is 4x. P4T533C is 3x. So, you have to choose 4X if you want to run PC1066 out of PC800.
So far P4T533-C is fairly stable. But I am really NOT impressed. Because the difference from P4T-E is just minimal. There is no performance gain. Even the board looks almost the same. somehow, P4T-E is better....
If you have a P4T-E like mine (with ICSxxx-13 chip), NO NEED to buy a P4T533-C like me
(1)Voltage:
(2)DDRG chips:
(4) on board audio:
(6) RDRAM default:
