- Feb 18, 2002
There are stability tests and stress tests that are run to make sure your overclock is fully stable. Some people run them for a short time, others run them for half a day or even a whole day, then adjust their overclocks if they fail these stability tests.
There are other reasons such as when people overclock in the winter and don't adjust for summer heat when temperatures go up inside their case, causing winter stable overclocks to fail.
Welcome to the forums.
Compare Thermalright heatsinks to cooler master and start a thread in the video card section called 2 msi 4890's or 1 nvidia gtx 285?
_____________________
Intel i7 920 [211] BCLK x 19 = 4.0 GHz @ [1.4500] CPU Voltage & [1.35000] QPI/DRAM Uncore Voltage, Batch 3836A394
3 x 1GB G.SKIL DDR3 1333 (PC3 10666) [DDR3-1691MHz] 10-10-10-24 @ 1.64 DRAM Bus Voltage
ASUS P6T Deluxe v.1 [LGA 1366 Intel X58] BIOS 1102
Thermalright Ultra-120 eXtreme 1366 RT with 120mm Scythe S-Flex F fan
ASUS EAH4850 TOP Radeon HD 4850 512MB @ 680 MHz GPU & 2100 MHz Memory
Antec nine hundred case, two front 120mm fans, one back 120mm Fan, one top 200mm fan
Corsair CMPSU-750TX 750W
