- Jan 29, 2012
Hi, I recently built a computer with the Asus P8Z68-V LX mobo, i5 2500K, 8GB RAM, 120gb SSD, 550W PSU, Antec 300 Case and the Arctic freezer pro 7.
As you probably know Asus has this auto overclock software that comes with the motherboard. I trusted that thinking that it would know what it was doing.
I set up 'fast' which just overclocks the CPU as I don't have any cooling on my RAM, 'extreme' oc the RAM as well as the CPU.
After rebooting it seemed fine, it said I had a 31% increase, from 3.3GHz to 4.5GHz, I thought great.
That was last night, starting up this morning the fans spin up and all the LEDs are on like normal then it fails and tries again, I think after the 3rd time of failing and trying again it goes into setup screen press F1 etc. I pressed F1 and it took me into the BIOS. As I didn't know what it had changed I went into boot and selected windows. Windows started normal and everything looked stable at 4.5GHz, temp was 35C.
I restarted it and it only failed once instead of 3 times. Leaving it a couple of hours and starting again it failed 3 times again. I turned down the CPU multiplier to 34 (3.4GHz) and it seemed stable. Shutting down and leaving it a couple of hours coming back to start it again it failed twice then started fine.
Temperatures are at 23C.
If anyone can tell me how to overclock this mobo and CPU safely would be great.
Or just get it stable again would be still good thanks.
