Can any one with this motherboard clarify if using both M.2 slots, will video card still run at full PCIE 4.0 specs? Also how many sata ports do I loose, 2 or 4? Thanks
The manual shares that info. It states on the specs table as well later in the document what is shared. In your case, you lose a pair of sata ports and some pcie lanes that are attached to CHIPSET PCIe. The primary gpu slot is connected via the cpu and doesn't lose a thing.
