I acquired an ASUS Sabertooth Z77 awhile ago but never got around to getting any components for it. I recently was given an Intel i7-3770K CPU though, so I've decided that I will go ahead and assemble a build. The problem I'm having at the moment though is the RAM ... I've browsed (briefly) around NewEgg (primarily because I'm ordering other components from that website) and come to the conclusion that it's a toss-up between these two modules, ( http://www.newegg.com/Product/Product.aspx?Item=N82E16820231624 & http://www.newegg.com/Product/Product.aspx?Item=N82E16820231626 ) "G.SKILL Trident X Series" and "G.SKILL Ripjaws Z Series" ... I was initially going to invest in the Trident because of the timings, but noticed that they are 1.6V vs the Ripjaws which is 1.5V ...
would it be easier to stick lower voltage modules on and then reduce the clocks? vs. a higher voltage stick? It's only 0.1V ... but it makes a difference--doesn't it (?does it make a difference?)?
