twinduct
- Nov 11, 2015
Hopefully someone will have the patience to spoon feed me...
So I built this rig with the intentions of using it for photography work with some 4k video viewing. The last few months it has been going good, but I would like to dial it in as I know now from reading this forum the asus ai suite doesn't fully take advantage of what I have. Using the auto tuner in bios I've read also doesn't utilize my hardware fully.
So far I've read from here: http://www.overclockers.com/forums/showthread.php/762037-Asus-X99-Deluxe-U3-1-Overclock-Failed
And http://www.overclockers.com/forums/...CPU-voltage-settings-need-an-experienced-user
That
So basically I need help with what to edit, in order, to get the most out of my setup. What about all the other things I can disable or enable under the advanced tab in bios? There seems to be so much you can change with regards to overclocking I'm a bit overwhelmed I must say. This is my first OC'ed rig and I haven't built one since the good ole Pentium 4 days lol. That wasn't hard though as computers haven't changed for the most part one bit.
My specs:
My cpu-z report.
https://drive.google.com/open?id=1UJdY9layIFZI9O3ZcvfuBCLxvKJNkCY45eKCvW-3sPI
Picture of my current setup.
That
Generally on X99 all you have to do to OC CPU and memory is to set CPU ratio, CPU voltage, memory clock and memory voltage if needed.
All other voltages are required only when you run CPU at really high clocks or when you set 3000+ memory clock at tighter timings.
Also disable C stages and EIST but keep Turbo enabled. In most cases you can keep everything enabled but usually it's easier to achieve full stability when these options are disabled.
My specs:
Code:
Intel Core i7-5930K 3.5GHz 6-Core Processor
G.Skill Ripjaws 4 series 32GB (4 x 8GB) DDR4-2800 Memory
NZXT Kraken X61 106.1 CFM Liquid CPU Cooler
Asus X99-A ATX LGA2011-3 Motherboard
Samsung SM951 128GB M.2-2280 Solid State Drive
EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card
Corsair 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply
Fractal Design Define XL R2 (Black Pearl) ATX Full Tower Case
X2 BenQ BL3201PH 60Hz 32.0" 4K Monitors
My cpu-z report.
