Hi,
I just got a new PC with the following:
Z390-F Gaming Motherboard
G.Skill Trident 3200MHZ CL16 DDR4
i7-9700K
GTX 1080
The RAM is 4 sticks of 8GB each. When all sticks are in the PC starts up but nothing shows up on the monitor, can't get into BIOS etc. I figured out that the only way to boot was to have one of the sticks plugged into slot 3 (second closest to the CPU) and then it works fine. I can boot into Windows and everything runs fine but I only have 8GB of RAM so that's definitely not optimal.
I looked a bit more and I realized that my RAM wasn't under the QVL for the MoBo.
My RAM is the: F4-3200C16D-16GTZR
So what I'm wondering now is:
1) Is something wrong with the motherboard?
2) Is the RAM faulty?
3) Is it just that the RAM is not fully compatible with the mobo which is why 1 stick works?
I am really hoping it's 3) because I'd hate having to return the motherboard and having to reseat everything
Anyone got any idea what exactly could be causing it? Should I just try with some other DDR4 RAM? Is the QVL that important?
i7-9700K
GTX 1080
