Note: Apologies if this has been written before, but in a recent poll (http://www.ocforums.com/showthread.php?t=350140&highlight=Poll) I found that an overwhelming majority of AMD users still use Athlon XPs, most notably of the Barton core. I hope none of you think me presumptuous for writing the “101” on Athlon XPs, but in the AMD section I find a real mention of only the AMD64s in stickies, and I apologise in advance for any minor mistakes I may make.
This is merely part one. If I receive a positive response, I’ll go on to discuss compatible motherboards, how XPs compare to Intel cpu’s and how to overclock. Plus more…
And why XPs are still a great buy for the budget pc gamer
But, if I don't get a great response, sorry for boring you.
Hope you enjoy this
Although the Athlon XP may be outdated, it is still by far the most used! This is for any user who is new to computing and owns an Athlon XP system.
Technical Terms
FSB = Front Side Bus. This is the speed at which the cpu communicates with the motherboard’s memory controller, via the Northbridge chip. FSB*Multiplier = Total CPU Speed
CPU = Central Processing Unit
North/Southbridge Chips = These are the two controllers on the motherboard. Traditionally, the northbridge controls the fast devices such as the cpu, memory, disk drives and so forth – whereas the southbridge controls the slower devices such as the mouse and keyboard.
Cache: A very small amount of memory built directly onto the cpu, allowing it to access previously completed calculations extremely quickly. There are three levels: L1, L2 and L3 – but the one most referred to is L2.
History of the Athlon XP
AMD (acronym for Advanced Micro Devices) was relatively unknown until the release of the original AMD Athlon processor – the first and last cpu to rival the Pentium 3. It was also the first processor to boast a dual-pumped FSB (more on that later.) In short, the original Athlon range was a roaring success.
But times moved on. Intel released the Pentium 4, which although hampered by its initial Willamette range, boasted an impressive technical spec. At this point, Intel was also trying to push the expensive Rambus memory in as a pc standard. Unless AMD acted, Rambus and Pentium 4 threatened the existence of the budget-cpu.
The Athlon XP 1500+ was the first of the XP range to be released. It worked with a new standard of memory that AMD pushed forward – DDRAM. This would eventually succeed in replacing the SDRAM standard, making Rambus obsolete. The difference was that Rambus was very expensive and boasted supposedly better performance, while DDRAM was considerably cheaper (fitting in line with AMD’s budget cpu.)
The XP 1500+ ran at 266Mhz FSB whereas Intel’s prototype Pentium 4 Willamette 1400 ran at 400Mhz FSB.
It is crucial to understand that AMD processors have always run at slower frequencies than their Intel counterparts, yet are capable of matching their rivals with less megahertz due to increased efficiency.
Previously AMD had labelled their processors by their actual clock speed: e.g. Athlon 1Ghz. But now they re-named their cpu’s to show the actual speed: e.g. Athlon XP 1500+ now meant that although the cpu might run at 1.2Ghz, it was the equivalent to an Intel P4 1.5Ghz, at least in the eyes of AMD.
The Athlon XP microprocessor had been born.
Cores
There are several different types of core in the Athlon XP range, listed in chronological order from oldest to newest:
Morgan: Later used for the Duron (budget series, rival to Celeron) these processors boasted a FSB of 266Mhz only. These went up to “1800+.”
Palomino: A newer processor and a replacement for the Morgan. This series of processor went all the way up to 333Mhz FSB, and extended the cpu’s L2 cache to 256k.
Thoroughbred: Again named after a racehorse, this processor was a superior version of the Palomino – and with it came increased speeds, all the way up to a “2800+” (2.09Ghz.) By this time, Quanti-Speed Architecture had been fully developed, allowing Athlon XPs to run even closer to their Intel counterparts.
Barton: The newest type of desktop core. These were identical to Thoroughbreds, except that they had double the amount of cache (512k.) This range extended all the way up to “3200+” (2.2Ghz) and also included two models running at 400Mhz FSB: the “3000+” and the “3200+” and there was also a “3000+” that ran at 333Mhz FSB.
Mobile Bartons: Abbreviated to XP-M, these processors are a rival to the P4-M range and include various technologies optimised for laptops – including the ability to reduce their clock speeds to conserve battery life. However, they quickly became known as excellent overclockers and as such were soon put to use in desktop pc’s.
Hope you enjoy this
Technical Terms
Cores
