CatSmasher
- Dec 21, 2006
There is no remote with that unit and the "free remote offer" is expired.
ScottinIndy said:I wouldn't mind picking one up myself, Would love to record some TV on the pc, Question, Will this card work with XP home or is it necessary to have media edition for PVR use?
i just gmailed these to myself... i do that all the time. i made a LABEL in gmail called "technical information" and i store information to myself like that and organize... then i use "search mail" option a few months from now to find it, when i have time.Reefa_Madness said:g0dM@n,
Here are some links to help you get started...from simple overviews to more detailed...and in no particular order (sorry).
http://www.techlore.com/article/10268/
http://www.film-to-video.com/tutorial_page02.html
http://www.pcstats.com/articleview.cfm?articleID=813
http://howtodothings.com/computers/a3487-how-to-transfer-vhs-to-dvd.html
http://www.virtualdub.org/
http://h71036.www7.hp.com/hho/cache/314608-0-0-225-121.html
Doing exactly this is why I got started messing with computers...I've had a blast playing and tweaking computers, but never got around to converting a single tape! How's that for irony???
lol... you're a genius!!Wicked Klown said:Not fair. I just bought myself a Christmas present instead. ...grumble.....grumble.... Looks like I might have to get myself another gift as well. I'll tell the wife it's for the dog, yea thats it for the dog.
Dermen said:I have never tried playing consoles but I have always read there is a 1-2 second delay that makes hooking up consoles a bad idea.
BossBorot said:From my experiences with another ATI tuner when you had a box somewhere in the advanced settings checked you could experience delayes both in tv and composite inputs. The box was something like best image quality or use post processing heck I dont fully remember but it implied hey check this if you want the image to look better. Basically if you had this checked sometimes in tv the audio and visual would go out of sync, because I asume that they are doing post processing on the image, and over composite sometimes the games would lag. After I unchecked that box it tended to be fine. Also tuners tend to have bad settings for composite when you first hook them up and the colors of your games will look to dark and blue, at least this was the case with the tv wonder pro. Basically if you dont enable any extra processing of the image you should be fine and take the time to adjust other settings.
heezer7 said:Before I had a ATI TV Wonder PCI (different than this one) and I found that games over some software programs was ok, and laggy over others. I believe I used Power VCR to play games w/o lag, but it has been a while. I don't remember which app it was for sure. You just have to find one that does not include the pause feature so the video is not being buffered and in turn delayed.
Avg said:@BossBorot
I don't have that app, and I have an ATi tuner, let me check the cd again.
BossBorot said:you can connect your consoles via the composite inputs on the purple break out box thingy that connects to the card. Then you load whatever program it comes with to watch tv and change the displayed input to composite. Basically this card comes with everything you need to connect your consoles to your comuter. Also you can record any input so by extention you can record your games if you want to which is a very nice feature to have. Note this is also how it can be used to rip dvd's or vhs to your hdd so long as it is legal that is... so this is how you would use the card to back up old vhs tapes etc.
I personally got a deal on a tv wonder pro a long time ago but I lost that darn purple box so I think I might just have to pick this up as well.
CatSmasher said:There is no remote with that unit and the "free remote offer" is expired.
