MSI GeForce 7600 GS 256 MB keeps crashing at 500 Mhz at Find max Core clocks, I tried increasing AGP voltage in the BIOS from 1.5V to 1.55V and that didn't work, and also 1.6V and it still crashed at 497 Mhz.
I'm playing around with stock cooling but the temps only read about 61°C at it's highest. Why won't it overclock any higher ?! Do I also need to find max mem clock for the core clock to reach higher speeds ?
Here is the log file:
2007-04-22 19:51:26 D Successfully connected to driver, version 130
2007-04-22 19:51:26 D Scanning for ATI VGA Cards...
2007-04-22 19:51:26 D Scanning for NVIDIA VGA Cards...
2007-04-22 19:51:26 D Found NVIDIA device: 0x10DE 0x02E1 bus 1 dev 0
2007-04-22 19:51:26 D fbPhy: 0xF9000000, mmrPhy: 0xF8000000.
2007-04-22 19:51:26 D mmapped mmr to 0x1840000
2007-04-22 19:51:26 D F75373 temp chip detection: failed (VendorID)
2007-04-22 19:51:26 D ADT7473 temp chip detection: failed (VendorID)
2007-04-22 19:51:56 I Find Max Core started...
2007-04-22 19:52:00 I Clocks level 0 set to: 400.00 / 400.00
2007-04-22 19:52:00 I Clocks level 1 set to: 400.00 / 400.00
2007-04-22 19:52:00 I Clocks level 2 set to: 400.00 / 400.00
2007-04-22 19:52:03 I Clocks level 0 set to: 403.00 / 400.00
2007-04-22 19:52:03 I Clocks level 1 set to: 403.00 / 400.00
2007-04-22 19:52:03 I Clocks level 2 set to: 406.00 / 400.00
2007-04-22 19:52:06 I Clocks level 0 set to: 406.00 / 400.00
2007-04-22 19:52:06 I Clocks level 1 set to: 406.00 / 400.00
2007-04-22 19:52:06 I Clocks level 2 set to: 409.00 / 400.00
2007-04-22 19:52:09 I Clocks level 0 set to: 409.00 / 400.00
2007-04-22 19:52:09 I Clocks level 1 set to: 409.00 / 400.00
2007-04-22 19:52:09 I Clocks level 2 set to: 409.00 / 400.00
2007-04-22 19:52:12 I Clocks level 0 set to: 409.00 / 400.00
2007-04-22 19:52:12 I Clocks level 1 set to: 409.00 / 400.00
2007-04-22 19:52:12 I Clocks level 2 set to: 415.00 / 400.00
2007-04-22 19:52:15 I Clocks level 0 set to: 415.00 / 400.00
2007-04-22 19:52:15 I Clocks level 1 set to: 415.00 / 400.00
2007-04-22 19:52:15 I Clocks level 2 set to: 418.00 / 400.00
2007-04-22 19:52:18 I Clocks level 0 set to: 418.00 / 400.00
2007-04-22 19:52:18 I Clocks level 1 set to: 418.00 / 400.00
2007-04-22 19:52:18 I Clocks level 2 set to: 421.00 / 400.00
2007-04-22 19:52:21 I Clocks level 0 set to: 421.00 / 400.00
2007-04-22 19:52:21 I Clocks level 1 set to: 421.00 / 400.00
2007-04-22 19:52:21 I Clocks level 2 set to: 424.00 / 400.00
2007-04-22 19:52:24 I Clocks level 0 set to: 424.00 / 400.00
2007-04-22 19:52:24 I Clocks level 1 set to: 424.00 / 400.00
2007-04-22 19:52:24 I Clocks level 2 set to: 424.00 / 400.00
2007-04-22 19:52:57 I Clocks level 0 set to: 424.00 / 400.00
2007-04-22 19:52:57 I Clocks level 1 set to: 424.00 / 400.00
2007-04-22 19:52:57 I Clocks level 2 set to: 430.00 / 400.00
2007-04-22 19:53:00 I Clocks level 0 set to: 430.00 / 400.00
2007-04-22 19:53:00 I Clocks level 1 set to: 430.00 / 400.00
2007-04-22 19:53:00 I Clocks level 2 set to: 433.00 / 400.00
2007-04-22 19:53:03 I Clocks level 0 set to: 433.00 / 400.00
2007-04-22 19:53:03 I Clocks level 1 set to: 433.00 / 400.00
2007-04-22 19:53:03 I Clocks level 2 set to: 436.00 / 400.00
2007-04-22 19:53:06 I Clocks level 0 set to: 436.00 / 400.00
2007-04-22 19:53:06 I Clocks level 1 set to: 436.00 / 400.00
2007-04-22 19:53:06 I Clocks level 2 set to: 436.00 / 400.00
2007-04-22 19:53:09 I Clocks level 0 set to: 436.00 / 400.00
2007-04-22 19:53:09 I Clocks level 1 set to: 436.00 / 400.00
2007-04-22 19:53:09 I Clocks level 2 set to: 442.00 / 400.00
2007-04-22 19:53:12 I Clocks level 0 set to: 442.00 / 400.00
2007-04-22 19:53:12 I Clocks level 1 set to: 442.00 / 400.00
2007-04-22 19:53:12 I Clocks level 2 set to: 445.00 / 400.00
2007-04-22 19:53:15 I Clocks level 0 set to: 445.00 / 400.00
2007-04-22 19:53:15 I Clocks level 1 set to: 445.00 / 400.00
2007-04-22 19:53:15 I Clocks level 2 set to: 448.00 / 400.00
2007-04-22 19:53:18 I Clocks level 0 set to: 448.00 / 400.00
2007-04-22 19:53:18 I Clocks level 1 set to: 448.00 / 400.00
2007-04-22 19:53:18 I Clocks level 2 set to: 448.00 / 400.00
2007-04-22 19:53:21 I Clocks level 0 set to: 448.00 / 400.00
2007-04-22 19:53:21 I Clocks level 1 set to: 448.00 / 400.00
2007-04-22 19:53:21 I Clocks level 2 set to: 454.00 / 400.00
2007-04-22 19:53:24 I Clocks level 0 set to: 454.00 / 400.00
2007-04-22 19:53:24 I Clocks level 1 set to: 454.00 / 400.00
2007-04-22 19:53:24 I Clocks level 2 set to: 457.00 / 400.00
2007-04-22 19:53:27 I Clocks level 0 set to: 457.00 / 400.00
2007-04-22 19:53:27 I Clocks level 1 set to: 457.00 / 400.00
2007-04-22 19:53:27 I Clocks level 2 set to: 457.00 / 400.00
2007-04-22 19:53:30 I Clocks level 0 set to: 457.00 / 400.00
2007-04-22 19:53:30 I Clocks level 1 set to: 457.00 / 400.00
2007-04-22 19:53:30 I Clocks level 2 set to: 463.00 / 400.00
2007-04-22 19:54:09 I Clocks level 0 set to: 463.00 / 400.00
2007-04-22 19:54:09 I Clocks level 1 set to: 463.00 / 400.00
2007-04-22 19:54:09 I Clocks level 2 set to: 466.00 / 400.00
2007-04-22 19:54:12 I Clocks level 0 set to: 466.00 / 400.00
2007-04-22 19:54:12 I Clocks level 1 set to: 466.00 / 400.00
2007-04-22 19:54:12 I Clocks level 2 set to: 466.00 / 400.00
2007-04-22 19:54:15 I Clocks level 0 set to: 466.00 / 400.00
2007-04-22 19:54:15 I Clocks level 1 set to: 466.00 / 400.00
2007-04-22 19:54:15 I Clocks level 2 set to: 472.00 / 400.00
2007-04-22 19:54:18 I Clocks level 0 set to: 472.00 / 400.00
2007-04-22 19:54:18 I Clocks level 1 set to: 472.00 / 400.00
2007-04-22 19:54:18 I Clocks level 2 set to: 475.00 / 400.00
2007-04-22 19:54:21 I Clocks level 0 set to: 475.00 / 400.00
2007-04-22 19:54:21 I Clocks level 1 set to: 475.00 / 400.00
2007-04-22 19:54:21 I Clocks level 2 set to: 478.00 / 400.00
2007-04-22 19:54:24 I Clocks level 0 set to: 478.00 / 400.00
2007-04-22 19:54:24 I Clocks level 1 set to: 478.00 / 400.00
2007-04-22 19:54:24 I Clocks level 2 set to: 481.00 / 400.00
2007-04-22 19:54:27 I Clocks level 0 set to: 481.00 / 400.00
2007-04-22 19:54:27 I Clocks level 1 set to: 481.00 / 400.00
2007-04-22 19:54:27 I Clocks level 2 set to: 484.00 / 400.00
2007-04-22 19:54:30 I Clocks level 0 set to: 484.00 / 400.00
2007-04-22 19:54:30 I Clocks level 1 set to: 484.00 / 400.00
2007-04-22 19:54:30 I Clocks level 2 set to: 484.00 / 400.00
2007-04-22 19:54:33 I Clocks level 0 set to: 484.00 / 400.00
2007-04-22 19:54:33 I Clocks level 1 set to: 484.00 / 400.00
2007-04-22 19:54:33 I Clocks level 2 set to: 490.00 / 400.00
2007-04-22 19:54:36 I Clocks level 0 set to: 490.00 / 400.00
2007-04-22 19:54:36 I Clocks level 1 set to: 490.00 / 400.00
2007-04-22 19:54:36 I Clocks level 2 set to: 493.00 / 400.00
2007-04-22 19:54:39 I Clocks level 0 set to: 493.00 / 400.00
2007-04-22 19:54:39 I Clocks level 1 set to: 493.00 / 400.00
2007-04-22 19:54:39 I Clocks level 2 set to: 496.00 / 400.00
2007-04-22 19:55:01 I Clocks level 0 set to: 496.00 / 400.00
2007-04-22 19:55:01 I Clocks level 1 set to: 498.00 / 400.00
2007-04-22 19:55:01 I Clocks level 2 set to: 498.00 / 400.00
2007-04-22 19:55:49 I Clocks level 0 set to: 500.00 / 400.00
2007-04-22 19:55:49 I Clocks level 1 set to: 500.00 / 400.00
2007-04-22 19:55:49 I Clocks level 2 set to: 500.00 / 400.00
2007-04-22 19:56:09 I Clocks level 0 set to: 503.00 / 400.00
2007-04-22 19:56:09 I Clocks level 1 set to: 503.00 / 400.00
2007-04-22 19:56:09 I Clocks level 2 set to: 503.00 / 400.00
2007-04-22 19:56:09 I Artifacts detected after 04:12.76. 56974 pixels don't match.
2007-04-22 19:56:25 I Artifacts detected after 00:16.00. 58932 pixels don't match.
2007-04-22 19:56:25 I Clocks level 0 set to: 501.00 / 400.00
2007-04-22 19:56:25 I Clocks level 1 set to: 501.00 / 400.00
2007-04-22 19:56:25 I Clocks level 2 set to: 501.00 / 400.00
2007-04-22 19:56:47 I Artifacts detected after 00:21.93. 56974 pixels don't match.
2007-04-22 19:56:47 I Clocks level 0 set to: 498.00 / 400.00
2007-04-22 19:56:47 I Clocks level 1 set to: 498.00 / 400.00
2007-04-22 19:56:47 I Clocks level 2 set to: 498.00 / 400.00
2007-04-22 19:56:47 I Scan aborted. Total runtime: 291 seconds. Artifact-free: 0 seconds. Core: 496.00 MHz Memory: 400.00 MHz
2007-04-22 19:57:06 I Clocks level 0 set to: 491.00 / 400.00
2007-04-22 19:57:06 I Clocks level 1 set to: 491.00 / 400.00
2007-04-22 19:57:06 I Clocks level 2 set to: 491.00 / 400.00
2007-04-22 19:57:28 I Clocks level 0 set to: 485.00 / 400.00
2007-04-22 19:57:28 I Clocks level 1 set to: 485.00 / 400.00
2007-04-22 19:57:28 I Clocks level 2 set to: 485.00 / 400.00
2007-04-22 19:59:30 I Clocks level 0 set to: 396.56 / 400.00
2007-04-22 19:59:30 I Clocks level 1 set to: 396.56 / 400.00
2007-04-22 19:59:30 I Clocks level 2 set to: 396.56 / 400.00
2007-04-22 19:59:43 I Clocks level 0 set to: 400.00 / 400.00
2007-04-22 19:59:43 I Clocks level 1 set to: 400.00 / 400.00
2007-04-22 19:59:43 I Clocks level 2 set to: 400.00 / 400.00
2007-04-22 19:59:47 I Clocks level 0 set to: 400.00 / 400.00
2007-04-22 19:59:47 I Clocks level 1 set to: 400.00 / 400.00
2007-04-22 19:59:47 I Clocks level 2 set to: 400.00 / 400.00
2007-04-22 19:59:49 I Clocks level 0 set to: 400.00 / 400.00
2007-04-22 19:59:49 I Clocks level 1 set to: 400.00 / 400.00
2007-04-22 19:59:49 I Clocks level 2 set to: 400.00 / 400.00
2007-04-22 20:00:45 I Application terminated.
2007-04-22 20:00:50 D Successfully connected to driver, version 130
2007-04-22 20:00:50 D Scanning for ATI VGA Cards...
2007-04-22 20:00:50 D Scanning for NVIDIA VGA Cards...
2007-04-22 20:00:51 D Found NVIDIA device: 0x10DE 0x02E1 bus 1 dev 0
2007-04-22 20:00:51 D fbPhy: 0xF9000000, mmrPhy: 0xF8000000.
2007-04-22 20:00:51 D mmapped mmr to 0x1840000
2007-04-22 20:00:51 D F75373 temp chip detection: failed (VendorID)
2007-04-22 20:00:51 D ADT7473 temp chip detection: failed (VendorID)
2007-04-22 20:00:53 I Scan for Artifacts started... Core: 400.00 MHz Memory: 400.00 MHz
2007-04-22 20:00:53 I Scan for Artifacts running for: 0:00:00
2007-04-22 20:01:52 I Scan for Artifacts stopped Total runtime: 58 seconds
2007-04-22 20:01:53 I Application terminated.
2007-04-23 21:41:10 D Successfully connected to driver, version 130
2007-04-23 21:41:10 D Scanning for ATI VGA Cards...
2007-04-23 21:41:10 D Scanning for NVIDIA VGA Cards...
2007-04-23 21:41:10 D Found NVIDIA device: 0x10DE 0x02E1 bus 1 dev 0
2007-04-23 21:41:10 D fbPhy: 0xF9000000, mmrPhy: 0xF8000000.
2007-04-23 21:41:10 D mmapped mmr to 0x1840000
2007-04-23 21:41:10 D F75373 temp chip detection: failed (VendorID)
2007-04-23 21:41:10 D ADT7473 temp chip detection: failed (VendorID)
2007-04-23 21:41:45 I Find Max Core started...
2007-04-23 21:41:49 I Clocks level 0 set to: 400.00 / 400.00
2007-04-23 21:41:49 I Clocks level 1 set to: 400.00 / 400.00
2007-04-23 21:41:49 I Clocks level 2 set to: 400.00 / 400.00
2007-04-23 21:41:52 I Clocks level 0 set to: 403.00 / 400.00
2007-04-23 21:41:52 I Clocks level 1 set to: 403.00 / 400.00
2007-04-23 21:41:52 I Clocks level 2 set to: 406.00 / 400.00
2007-04-23 21:41:55 I Clocks level 0 set to: 406.00 / 400.00
2007-04-23 21:41:55 I Clocks level 1 set to: 406.00 / 400.00
2007-04-23 21:41:55 I Clocks level 2 set to: 409.00 / 400.00
2007-04-23 21:41:58 I Clocks level 0 set to: 409.00 / 400.00
2007-04-23 21:41:58 I Clocks level 1 set to: 409.00 / 400.00
2007-04-23 21:41:58 I Clocks level 2 set to: 409.00 / 400.00
2007-04-23 21:42:01 I Clocks level 0 set to: 409.00 / 400.00
2007-04-23 21:42:01 I Clocks level 1 set to: 409.00 / 400.00
2007-04-23 21:42:01 I Clocks level 2 set to: 415.00 / 400.00
2007-04-23 21:42:04 I Clocks level 0 set to: 415.00 / 400.00
2007-04-23 21:42:04 I Clocks level 1 set to: 415.00 / 400.00
2007-04-23 21:42:04 I Clocks level 2 set to: 418.00 / 400.00
2007-04-23 21:42:07 I Clocks level 0 set to: 418.00 / 400.00
2007-04-23 21:42:07 I Clocks level 1 set to: 418.00 / 400.00
2007-04-23 21:42:07 I Clocks level 2 set to: 421.00 / 400.00
2007-04-23 21:42:10 I Clocks level 0 set to: 421.00 / 400.00
2007-04-23 21:42:10 I Clocks level 1 set to: 421.00 / 400.00
2007-04-23 21:42:10 I Clocks level 2 set to: 424.00 / 400.00
2007-04-23 21:42:13 I Clocks level 0 set to: 424.00 / 400.00
2007-04-23 21:42:13 I Clocks level 1 set to: 424.00 / 400.00
2007-04-23 21:42:13 I Clocks level 2 set to: 424.00 / 400.00
2007-04-23 21:42:46 I Clocks level 0 set to: 424.00 / 400.00
2007-04-23 21:42:46 I Clocks level 1 set to: 424.00 / 400.00
2007-04-23 21:42:46 I Clocks level 2 set to: 430.00 / 400.00
2007-04-23 21:42:49 I Clocks level 0 set to: 430.00 / 400.00
2007-04-23 21:42:49 I Clocks level 1 set to: 430.00 / 400.00
2007-04-23 21:42:49 I Clocks level 2 set to: 433.00 / 400.00
2007-04-23 21:42:52 I Clocks level 0 set to: 433.00 / 400.00
2007-04-23 21:42:52 I Clocks level 1 set to: 433.00 / 400.00
2007-04-23 21:42:52 I Clocks level 2 set to: 436.00 / 400.00
2007-04-23 21:42:55 I Clocks level 0 set to: 436.00 / 400.00
2007-04-23 21:42:55 I Clocks level 1 set to: 436.00 / 400.00
2007-04-23 21:42:55 I Clocks level 2 set to: 436.00 / 400.00
2007-04-23 21:42:58 I Clocks level 0 set to: 436.00 / 400.00
2007-04-23 21:42:58 I Clocks level 1 set to: 436.00 / 400.00
2007-04-23 21:42:58 I Clocks level 2 set to: 442.00 / 400.00
2007-04-23 21:43:01 I Clocks level 0 set to: 442.00 / 400.00
2007-04-23 21:43:01 I Clocks level 1 set to: 442.00 / 400.00
2007-04-23 21:43:01 I Clocks level 2 set to: 445.00 / 400.00
2007-04-23 21:43:04 I Clocks level 0 set to: 445.00 / 400.00
2007-04-23 21:43:04 I Clocks level 1 set to: 445.00 / 400.00
2007-04-23 21:43:04 I Clocks level 2 set to: 448.00 / 400.00
2007-04-23 21:43:07 I Clocks level 0 set to: 448.00 / 400.00
2007-04-23 21:43:07 I Clocks level 1 set to: 448.00 / 400.00
2007-04-23 21:43:07 I Clocks level 2 set to: 448.00 / 400.00
2007-04-23 21:43:10 I Clocks level 0 set to: 448.00 / 400.00
2007-04-23 21:43:10 I Clocks level 1 set to: 448.00 / 400.00
2007-04-23 21:43:10 I Clocks level 2 set to: 454.00 / 400.00
2007-04-23 21:43:13 I Clocks level 0 set to: 454.00 / 400.00
2007-04-23 21:43:13 I Clocks level 1 set to: 454.00 / 400.00
2007-04-23 21:43:13 I Clocks level 2 set to: 457.00 / 400.00
2007-04-23 21:43:16 I Clocks level 0 set to: 457.00 / 400.00
2007-04-23 21:43:16 I Clocks level 1 set to: 457.00 / 400.00
2007-04-23 21:43:16 I Clocks level 2 set to: 457.00 / 400.00
2007-04-23 21:43:19 I Clocks level 0 set to: 457.00 / 400.00
2007-04-23 21:43:19 I Clocks level 1 set to: 457.00 / 400.00
2007-04-23 21:43:19 I Clocks level 2 set to: 463.00 / 400.00
2007-04-23 21:43:58 I Clocks level 0 set to: 463.00 / 400.00
2007-04-23 21:43:58 I Clocks level 1 set to: 463.00 / 400.00
2007-04-23 21:43:58 I Clocks level 2 set to: 466.00 / 400.00
2007-04-23 21:44:01 I Clocks level 0 set to: 466.00 / 400.00
2007-04-23 21:44:01 I Clocks level 1 set to: 466.00 / 400.00
2007-04-23 21:44:01 I Clocks level 2 set to: 466.00 / 400.00
2007-04-23 21:44:04 I Clocks level 0 set to: 466.00 / 400.00
2007-04-23 21:44:04 I Clocks level 1 set to: 466.00 / 400.00
2007-04-23 21:44:04 I Clocks level 2 set to: 472.00 / 400.00
2007-04-23 21:44:07 I Clocks level 0 set to: 472.00 / 400.00
2007-04-23 21:44:07 I Clocks level 1 set to: 472.00 / 400.00
2007-04-23 21:44:07 I Clocks level 2 set to: 475.00 / 400.00
2007-04-23 21:44:10 I Clocks level 0 set to: 475.00 / 400.00
2007-04-23 21:44:10 I Clocks level 1 set to: 475.00 / 400.00
2007-04-23 21:44:10 I Clocks level 2 set to: 478.00 / 400.00
2007-04-23 21:44:13 I Clocks level 0 set to: 478.00 / 400.00
2007-04-23 21:44:13 I Clocks level 1 set to: 478.00 / 400.00
2007-04-23 21:44:13 I Clocks level 2 set to: 481.00 / 400.00
2007-04-23 21:44:16 I Clocks level 0 set to: 481.00 / 400.00
2007-04-23 21:44:16 I Clocks level 1 set to: 481.00 / 400.00
2007-04-23 21:44:16 I Clocks level 2 set to: 484.00 / 400.00
2007-04-23 21:44:19 I Clocks level 0 set to: 484.00 / 400.00
2007-04-23 21:44:19 I Clocks level 1 set to: 484.00 / 400.00
2007-04-23 21:44:19 I Clocks level 2 set to: 484.00 / 400.00
2007-04-23 21:44:22 I Clocks level 0 set to: 484.00 / 400.00
2007-04-23 21:44:22 I Clocks level 1 set to: 484.00 / 400.00
2007-04-23 21:44:22 I Clocks level 2 set to: 490.00 / 400.00
2007-04-23 21:44:25 I Clocks level 0 set to: 490.00 / 400.00
2007-04-23 21:44:25 I Clocks level 1 set to: 490.00 / 400.00
2007-04-23 21:44:25 I Clocks level 2 set to: 493.00 / 400.00
2007-04-23 21:44:28 I Clocks level 0 set to: 493.00 / 400.00
2007-04-23 21:44:28 I Clocks level 1 set to: 493.00 / 400.00
2007-04-23 21:44:28 I Clocks level 2 set to: 496.00 / 400.00
2007-04-23 21:44:31 I Clocks level 0 set to: 496.00 / 400.00
2007-04-23 21:44:31 I Clocks level 1 set to: 496.00 / 400.00
2007-04-23 21:44:31 I Clocks level 2 set to: 499.00 / 400.00
2007-04-23 21:44:52 I Clocks level 0 set to: 499.00 / 400.00
2007-04-23 21:44:52 I Clocks level 1 set to: 501.00 / 400.00
2007-04-23 21:44:52 I Clocks level 2 set to: 501.00 / 400.00
2007-04-23 21:45:44 I Clocks level 0 set to: 503.00 / 400.00
2007-04-23 21:45:44 I Clocks level 1 set to: 503.00 / 400.00
2007-04-23 21:45:44 I Clocks level 2 set to: 503.00 / 400.00
2007-04-23 21:46:00 I Clocks level 0 set to: 503.00 / 400.00
2007-04-23 21:46:00 I Clocks level 1 set to: 503.00 / 400.00
2007-04-23 21:46:00 I Clocks level 2 set to: 503.00 / 400.00
2007-04-23 21:46:00 I Artifacts detected after 04:13.95. 56974 pixels don't match.
2007-04-23 21:46:00 I Clocks level 0 set to: 507.00 / 400.00
2007-04-23 21:46:00 I Clocks level 1 set to: 507.00 / 400.00
2007-04-23 21:46:00 I Clocks level 2 set to: 507.00 / 400.00
2007-04-23 21:46:16 I Artifacts detected after 00:15.95. 56974 pixels don't match.
2007-04-23 21:46:16 I Clocks level 0 set to: 504.00 / 400.00
2007-04-23 21:46:16 I Clocks level 1 set to: 504.00 / 400.00
2007-04-23 21:46:16 I Clocks level 2 set to: 504.00 / 400.00
2007-04-23 21:48:19 D Successfully connected to driver, version 130
2007-04-23 21:48:19 D Scanning for ATI VGA Cards...
2007-04-23 21:48:19 D Scanning for NVIDIA VGA Cards...
2007-04-23 21:48:19 D Found NVIDIA device: 0x10DE 0x02E1 bus 1 dev 0
2007-04-23 21:48:19 D fbPhy: 0xF9000000, mmrPhy: 0xF8000000.
2007-04-23 21:48:19 D mmapped mmr to 0x1840000
2007-04-23 21:48:19 D F75373 temp chip detection: failed (VendorID)
2007-04-23 21:48:19 D ADT7473 temp chip detection: failed (VendorID)
2007-04-23 21:48:32 I Find Max Core started...
2007-04-23 21:48:36 I Clocks level 0 set to: 400.00 / 400.00
2007-04-23 21:48:36 I Clocks level 1 set to: 400.00 / 400.00
2007-04-23 21:48:36 I Clocks level 2 set to: 400.00 / 400.00
2007-04-23 21:48:39 I Clocks level 0 set to: 403.00 / 400.00
2007-04-23 21:48:39 I Clocks level 1 set to: 403.00 / 400.00
2007-04-23 21:48:39 I Clocks level 2 set to: 406.00 / 400.00
2007-04-23 21:48:42 I Clocks level 0 set to: 406.00 / 400.00
2007-04-23 21:48:42 I Clocks level 1 set to: 406.00 / 400.00
2007-04-23 21:48:42 I Clocks level 2 set to: 409.00 / 400.00
2007-04-23 21:48:45 I Clocks level 0 set to: 409.00 / 400.00
2007-04-23 21:48:45 I Clocks level 1 set to: 409.00 / 400.00
2007-04-23 21:48:45 I Clocks level 2 set to: 409.00 / 400.00
2007-04-23 21:48:48 I Clocks level 0 set to: 409.00 / 400.00
2007-04-23 21:48:48 I Clocks level 1 set to: 409.00 / 400.00
2007-04-23 21:48:48 I Clocks level 2 set to: 415.00 / 400.00
2007-04-23 21:48:51 I Clocks level 0 set to: 415.00 / 400.00
2007-04-23 21:48:51 I Clocks level 1 set to: 415.00 / 400.00
2007-04-23 21:48:51 I Clocks level 2 set to: 418.00 / 400.00
2007-04-23 21:48:54 I Clocks level 0 set to: 418.00 / 400.00
2007-04-23 21:48:54 I Clocks level 1 set to: 418.00 / 400.00
2007-04-23 21:48:54 I Clocks level 2 set to: 421.00 / 400.00
2007-04-23 21:48:55 I Scan aborted. Total runtime: 22 seconds. Artifact-free: 22 seconds. Core: 421.00 MHz Memory: 400.00 MHz
2007-04-23 21:49:12 I Clocks level 0 set to: 421.00 / 400.00
2007-04-23 21:49:12 I Clocks level 1 set to: 421.00 / 400.00
2007-04-23 21:49:12 I Clocks level 2 set to: 450.00 / 400.00
2007-04-23 21:49:13 I Find Max Core started...
2007-04-23 21:49:16 I Clocks level 0 set to: 450.00 / 400.00
2007-04-23 21:49:16 I Clocks level 1 set to: 450.00 / 400.00
2007-04-23 21:49:16 I Clocks level 2 set to: 453.00 / 400.00
2007-04-23 21:49:19 I Clocks level 0 set to: 453.00 / 400.00
2007-04-23 21:49:19 I Clocks level 1 set to: 453.00 / 400.00
2007-04-23 21:49:19 I Clocks level 2 set to: 456.00 / 400.00
2007-04-23 21:49:22 I Clocks level 0 set to: 456.00 / 400.00
2007-04-23 21:49:22 I Clocks level 1 set to: 456.00 / 400.00
2007-04-23 21:49:22 I Clocks level 2 set to: 459.00 / 400.00
2007-04-23 21:49:25 I Clocks level 0 set to: 459.00 / 400.00
2007-04-23 21:49:25 I Clocks level 1 set to: 459.00 / 400.00
2007-04-23 21:49:25 I Clocks level 2 set to: 462.00 / 400.00
2007-04-23 21:49:28 I Clocks level 0 set to: 462.00 / 400.00
2007-04-23 21:49:28 I Clocks level 1 set to: 462.00 / 400.00
2007-04-23 21:49:28 I Clocks level 2 set to: 465.00 / 400.00
2007-04-23 21:49:31 I Clocks level 0 set to: 465.00 / 400.00
2007-04-23 21:49:31 I Clocks level 1 set to: 465.00 / 400.00
2007-04-23 21:49:31 I Clocks level 2 set to: 468.00 / 400.00
2007-04-23 21:49:34 I Clocks level 0 set to: 468.00 / 400.00
2007-04-23 21:49:34 I Clocks level 1 set to: 468.00 / 400.00
2007-04-23 21:49:35 I Clocks level 2 set to: 471.00 / 400.00
2007-04-23 21:49:38 I Clocks level 0 set to: 471.00 / 400.00
2007-04-23 21:49:38 I Clocks level 1 set to: 471.00 / 400.00
2007-04-23 21:49:38 I Clocks level 2 set to: 474.00 / 400.00
2007-04-23 21:49:41 I Clocks level 0 set to: 474.00 / 400.00
2007-04-23 21:49:41 I Clocks level 1 set to: 474.00 / 400.00
2007-04-23 21:49:41 I Clocks level 2 set to: 474.00 / 400.00
2007-04-23 21:50:13 I Clocks level 0 set to: 474.00 / 400.00
2007-04-23 21:50:13 I Clocks level 1 set to: 474.00 / 400.00
2007-04-23 21:50:13 I Clocks level 2 set to: 480.00 / 400.00
2007-04-23 21:50:16 I Clocks level 0 set to: 480.00 / 400.00
2007-04-23 21:50:16 I Clocks level 1 set to: 480.00 / 400.00
2007-04-23 21:50:16 I Clocks level 2 set to: 483.00 / 400.00
2007-04-23 21:50:19 I Clocks level 0 set to: 483.00 / 400.00
2007-04-23 21:50:19 I Clocks level 1 set to: 483.00 / 400.00
2007-04-23 21:50:19 I Clocks level 2 set to: 486.00 / 400.00
2007-04-23 21:50:22 I Clocks level 0 set to: 486.00 / 400.00
2007-04-23 21:50:22 I Clocks level 1 set to: 486.00 / 400.00
2007-04-23 21:50:22 I Clocks level 2 set to: 489.00 / 400.00
2007-04-23 21:50:25 I Clocks level 0 set to: 489.00 / 400.00
2007-04-23 21:50:25 I Clocks level 1 set to: 489.00 / 400.00
2007-04-23 21:50:25 I Clocks level 2 set to: 492.00 / 400.00
2007-04-23 21:50:28 I Clocks level 0 set to: 492.00 / 400.00
2007-04-23 21:50:28 I Clocks level 1 set to: 492.00 / 400.00
2007-04-23 21:50:28 I Clocks level 2 set to: 495.00 / 400.00
2007-04-23 21:52:25 D Successfully connected to driver, version 130
2007-04-23 21:52:25 D Scanning for ATI VGA Cards...
2007-04-23 21:52:25 D Scanning for NVIDIA VGA Cards...
2007-04-23 21:52:25 D Found NVIDIA device: 0x10DE 0x02E1 bus 1 dev 0
2007-04-23 21:52:25 D fbPhy: 0xF9000000, mmrPhy: 0xF8000000.
2007-04-23 21:52:25 D mmapped mmr to 0x1840000
2007-04-23 21:52:25 D F75373 temp chip detection: failed (VendorID)
2007-04-23 21:52:25 D ADT7473 temp chip detection: failed (VendorID)
2007-04-23 21:52:29 I Application terminated.
