- Jun 20, 2001
- Vancouver, WA
- Thread Starter
- #41
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder26) Thu Feb 14 18:13:41 PST 2008
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
#InputDevice "stylus"
InputDevice "stylus" "SendCoreEvents"
InputDevice "cursor" "SendCoreEvents"
InputDevice "eraser" "SendCoreEvents"
#InputDevice "pad"
EndSection
Section "Files"
RgbPath "/usr/lib/X11/rgb"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
Load "wacom"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "keyboard"
EndSection
Driver "wacom"
Identifier "stylus"
#Option "SendCoreEvents" "true"
Option "USB " "on"
Option "Device" "/dev/input/tablet-intuos2-9x12"
#Option "Device" "/dev/ttyS0" # Change to
# /dev/input/event
# for USB
Option "Type" "stylus"
#Option "ForceDevice" "ISDV4" # Tablet PC ONLY
Option "DebugLevel" "11"
EndSection
Driver "wacom"
Identifier "eraser"
Option "USB " "on"
# /dev/input/event
# for USB
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
Option "USB " "on"
# /dev/input/event
# for USB
Option "Type" "cursor"
EndSection
#Section "InputDevice"
# Driver "wacom"
# Identifier "pad"
# #Option "Device" "/dev/ttyS0" # SERIAL ONLY
# Option "Device" "/dev/input/tablet-cintiq20wsx"
# Option "Type" "pad"
# Option "USB" "on" # USB ONLY
#EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 30.0 - 110.0
VertRefresh 50.0 - 150.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "NoLogo" "True"
Option "RandRRotation" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
#Virtual 2560 2560
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
make test_applet2
cd ../examples && appletviewer JTablet-test2.html
using java 2! (v1.4+!)
Closing all known tablets.
Tablet(s) closed.
Connected to X server.
Enumerating devices...
Found: deviceInfo[0].name = Virtual core keyboard, type = 0, id = 0
Constructing new TabletDevice (id = 0, type = 0)
Constructing new WacomDevice (id = 0, type = 0)
Not an extension device!
Name does not match one of recognized types.!
Found: deviceInfo[1].name = Virtual core pointer, type = 0, id = 1
Constructing new TabletDevice (id = 1, type = 0)
Constructing new WacomDevice (id = 1, type = 0)
Found: deviceInfo[2].name = stylus, type = 210, id = 2
Constructing new TabletDevice (id = 2, type = 210)
Constructing new WacomDevice (id = 2, type = 210)
Found: deviceInfo[3].name = Mouse0, type = 90, id = 3
Constructing new TabletDevice (id = 3, type = 90)
Constructing new WacomDevice (id = 3, type = 90)
Mouse not supported.
Found: deviceInfo[4].name = Keyboard0, type = 89, id = 4
Constructing new TabletDevice (id = 4, type = 89)
Constructing new WacomDevice (id = 4, type = 89)
No tablet(s) detected.
cello.tablet.JTabletException: Could not initialize tablet.
at cello.tablet.JTablet.initializeTablet(Native Method)
at cello.tablet.JTablet.<init>(JTablet.java:84)
at cello.tablet.JTablet.<init>(JTablet.java:72)
at cello.tablettest.JTablettest2.init(Unknown Source)
at sun.applet.AppletPanel.run(AppletPanel.java:419)
at java.lang.Thread.run(Thread.java:619)
java.lang.NullPointerException
Tablet(s) closed.
Found: deviceInfo[2].name = eraser, type = 210, id = 2
Found: deviceInfo[3].name = cursor, type = 211, id = 3
Constructing new TabletDevice (id = 3, type = 211)
Constructing new WacomDevice (id = 3, type = 211)
Found: deviceInfo[4].name = stylus, type = 212, id = 4
Constructing new TabletDevice (id = 4, type = 212)
Constructing new WacomDevice (id = 4, type = 212)
Found: deviceInfo[5].name = Mouse0, type = 90, id = 5
Constructing new TabletDevice (id = 5, type = 90)
Constructing new WacomDevice (id = 5, type = 90)
Found: deviceInfo[6].name = Keyboard0, type = 89, id = 6
Constructing new TabletDevice (id = 6, type = 89)
Constructing new WacomDevice (id = 6, type = 89)
Tablet(s) closed.
$ make
# make install
$ make test_applet2
$ make
$ cd X11
# make JDKinstall
$ cd ..
$ make test_applet2
DEBUGMODE = 1
#DEBUGMODE = 1
Warning: Can't read AppletViewer properties file: /root/.hotjava/properties Using defaults.
INFO : Closing all known tablets.
INFO : Tablet(s) closed.
INFO : Connected to X server.
INFO : Enumerating devices...
INFO : Constructing new XTabletDevice (id = 0, type = 0)
INFO : Constructing new XWacomDevice (id = 0, type = 0)
INFO : + Device failed test, but allowing anyway...
WARN : ! This device failed one or more compatibility checks
INFO : Constructing new XTabletDevice (id = 1, type = 0)
INFO : Constructing new XWacomDevice (id = 1, type = 0)
INFO : Constructing new XTabletDevice (id = 2, type = 89)
INFO : Constructing new XWacomDevice (id = 2, type = 89)
INFO : Constructing new XTabletDevice (id = 3, type = 90)
INFO : Constructing new XWacomDevice (id = 3, type = 90)
INFO : Constructing new XTabletDevice (id = 4, type = 216)
INFO : Constructing new XWacomDevice (id = 4, type = 216)
INFO : Tablet(s) initialized.
INFO : Cursors differ! Was cursorPhysicalId = 65535, cursorId = 65535; Now cursorPhysicalId = 4, cursorId = 4
INFO : Initializing Cursor cursorPhysicalId = 4, cursorId = 4.
INFO : Getting cursor data
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x7f9f0fad, pid=15263, tid=2142903184
# Java VM: Java HotSpot(TM) Server VM (10.0-b22 mixed mode linux-x86)
# Problematic frame:
# C [libjtablet.so+0x4fad] _ZN12XWacomDevice11GetAxisInfoEli+0x3d
# An error report file with more information is saved as:
# /home/marupa/Desktop/jtablet-sdk-v0.9.5_linux/examples/hs_err_pid15263.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Aborted
make: *** [test_applet2] Error 134
cd ../examples && appletviewer JTablet-test.html
