- Apr 1, 2002
- Thread Starter
- #61
Re: Audigy LS - what is the model number (CT#### or SB####)?
Re: Pinout orientation: there are two pins missing so you should be able to figure it out from there. Pins one and two are usually the farthest away from the motherboard (on all the cards I've seen). Easiest way to double check is to put a multimeter on what you think are pins one and three (you should get ~5VDC) - if you've got it upside down you'll be measuring between two ground pins (it'll read 0VDC). You got the rest correct.
