I am waiting for a new AW9D-Max, E6600, memory, power supply, and graphics card to be delivered. In anticipation of receiving these new toys, I am now thinking about the details of installing these upgrades.
The Silent OTES system uses heat pipes to transport heat to the large heat sink on the rear of the board, adjacent to the eSATA1 connector. Even though this large heat sink is adjacent to a ventilation opening, how is the heat rejected from the case effciently without a fan? The ventilation openings are horizontally located with respect to the large heat sink so natural convection will not occur between the inside and outside of the case.
I noticed from the manual that there are two fan connectors adjacent to the large heat sink labled "OTESFANx". Does this imply I am incorrect in assuming there is no factory installed OTES fan?
If there is indeed no factory fan installed, has anyone installed a small relatively silent fan on the large heat sink to at least break up the boundary layer of hot stagnant air along the heat sink surfaces?
I ordered the AW9D-MAX on the basis of some excellent long time experience with ABIT boards including two IC7-MAX2 currently in use. However, the Silent OTES concept concerns be because it appears the large heat sink is simply dumping the transferred heat inside the case. Once this area warms up, the heat pipes will simply stop working. Installing a fan to remove this heat would then negate the concept of "Silent" in Silent OTES.
