- Oct 13, 2010
- Hawaii, Kauai
Today I laughed at myself.
Figures that the Intel socket that comes with my noctua nh-d14 that I bought back in 2010 only says this. Doesnt say anything about 1155. I recently purchased an 1155 system and the nh-d14 bracket says 1156. Would it work?
Lol before I bought my 1155 system I visited newegg and browse the nh-d14 that I bought before if it would be compatible. And it says it does 1155. Probably because they upgrade the mounting?
I hope you guys do understand what I mean . Would the 1156 bracket on my nh-d14 work with my 1155?
Any advise are appreciated
Thanks
Edit:
Woah lucky lucky xD
If you guys take a look at this video on youtube. If you skip at where he install the noctua-nhd14. Pause at where the backplate is and he is saying supports 1155 but the backplate says only 1366/1156/755. He installed with an i7-2600k. Does this mean the 1156 backplate socket that I currently have will work with the 1155? I guess? no?
Also, why does he install his nh-d14 upwards? Because of 1155 socket? Back in my am3 I installed it sidewards. Does it matter? Intel=upward AMD=Sideward? Either way? Which angle is better? I have an airflow of side+front= air in. top+back= air out.
Thanks
Edit:
Woah lucky lucky xD
