This is my current timings and I was wondering what Bank Cycle Time (tRC) is exactly.
¿Is the current value optimal or should I set it lower? Thanks in advance.
tRC Timing: Row Cycle Time. The minimum time in cycles it takes a row to complete a full cycle. This can be determined by; tRC = tRAS + tRP. If this is set too short it can cause corruption of data and if it is to high, it will cause a loss in performance, but increase stability.
You can play with tRC if you want but effects won't be so visible. Usually can be tuned +/- 10 and higher or lower will cause instability. Too high should cause drop in performance but for DDR3 it often looks like no boot at all.
In theory it's tRC = tRAS + tRP but I haven't seen any memory above 1600 set like that.
In your case it's not worth to play with it and if you look for higher memory performance then I would advice to check if you can set higher CPU-NB clock rather than tighter timings.
I manage to fiddle about with the timings more, following a setup that Aida64 showed and it worked.
Did a Prime95 Blend test for 2 hours and I've been using the PC with that configuration for 2 days and no glitch so far.
Unless I'm missing something, I don't see what was accomplished. In the pic. above, the effective DRAM frequency and timings are the same as what the modules are rated to run at (assuming the 7-7-7-19-26 1T timings listed in your sig. are the default at DDR3-1333).
