- Jan 12, 2001
- Kansas, USA
Hey, welcome to Bat's mini reviews on mundane accessories, or basically, much ado about nothing.
Since everyone and their mother are doing reviews nowadays, I figured, why not? Maybe I will too?
Overview:
Let's look to see what got delivered today. All "storage section" related items too I might add. Upper left part of the photo contains two black boxes: 2X Asus Hyper M.2 X4 Mini. You connect and secure a m.2 NVMe SSD onto this expansion card and pop it into a PCI-e 3.0 slot. I only have two m.2 sockets on my motherboard. With these expansion cards, I can add more NVNe drives (i.e. in case I wanted to do some sort of RAID configuration). These cards also works with something called Asus Hyper Kit that is apparently supported by some Asus motherboards. I have no clue what that is at the moment, but we'll learn all about it in a later mini review.
Moving on to the topic of Bat's mini review part 1. The item in the lower left part of the photo is a bracket to mount a 2.5" drive into a 3.5" HDD drive cage or 3.5" floppy drive bay. This one has a 60mm cooling fan and is made by Rosewill (model no. RDRD-11003 in stock at newegg for $5.99). I figure the fan is a cheap wimpy thing. But, wait a minute! Whoa! Looks like I've already introduced bias into my review. Ok, fair enough, I will now assume the fan is innocent until proven guilty (yeah right). I'll give it a fair test and see it actually drops temps.
The item in the lower middle part of the photo is a Samsung 850 EVO 500GB 2.5" SATA SSD. This drive will also be part of this mini review part 1. Here's what I hope to accomplish. I intend to mount the SSD onto the bracket and test temps of the drive with the fan and without the fan running to see if this thing even works. It also appears to me the fan could be removed and a second 2.5" SSD would mount right in. I will do that to see if my theory is correct. I also have a couple other more powerful 60mm fans that I can try to see how they stack up to the fan that was provided.
Before we move on to mini review #1, the last things in the pic are: upper right, a 10 pack of Blu-Ray BD-R DL media. That will be another mini review in a couple days. I will test out my new Blu-Ray burner and see if the average overclocker can figure out how use these new Dual Layer discs to store 50 GB of data files (and whether it really works as advertised). The last items in the photo are 25mm fans that I plan to try mounting onto the heatsink that I installed onto my m.2 NVMe drive. Yes, that will be yet another Batty mini review. So, one delivery box turns into 4 mini reviews.
The Rosewill 3.5" to 2.5" HDD/SSD bracket is extremely light weight, but feels sturdy. No label on the fan to give us a clue what it is and what it'll do. Taking into account the low price of the bracket, it seems logical the fan is a cheap generic, but that said, we'll test it and see. Personally, I don't see why they didn't sleeve the fan wires. I did my usual old school electrical tape wrap. Probably a waste of time and tape, because if I were a betting man, I'd bet real money that I'll end up either using no fan or a different fan.
The Samsung 850 EVO 2.5" SSD fits perfectly onto the bracket. There are little guides on the bracket the position the drive exactly where it needs to go. A small pack of screws were enclosed in the package to mount the drive to the bracket and to mount the bracket to the case drive cage. Even with the SSD mounted, the unit is super light. Even if the fan is a flop, the bracket itself is fine for what it does, which is mount 2.5" drives.
Bat's mini review part 1 will continue. Stay tuned. Up next, Sammy drive and Rosey adapter are installed.
Note: If the fan is removed, you can mount a second 2.5" SSD onto the bracket. I didn't have a second drive at hand, but I trial fitted the one I had in both positions and there is even a small gap in between the two drives if you doubled up. Of course, the fan can't be used... or can it? I have a drive cage where the bottom is open in the middle, so if the bracket is mounted in the lowest cage bay, I could mount the fan onto the underside of the bracket (after you slide the bracket into the bay/cage first).
But, I'm getting ahead of myself. Let me show you an end view and a bottom view of the drive and bracket to give you a better idea how the fan fits in.
Here 's the bottom view.
Folks, this is a live review, give me a few minutes to shut down and pull the drive cage out of the case and then install this bracket/SSD drive.
***time passes***
EDIT #1: I'm having technical problems. The new SSD SATA drive is not showing up.
EDIT #2: Ok, I found the instructions that came with the drive and I will now follow them.
Continued...
Well, I learned something new today, how to set up a SSD that is not the boot drive.
Being a charge ahead kind of guy, I stuck the new SSD into my tower case, plugged it in, and booted up. The drive was not recognized. Samsung SATA SSD has a CD with software and drivers you are supposed to install first. Yes, I actually did eventually stop and read the instruction (almost worse than stopping to ask directions when you're driving). So, I found out the Samsung Magician program that is provided on the installation disc is supposed to walk you through the process. It got to the point where it said to reboot and the magician would finish initializing the drive after Windows restarted. I rebooted, no magician to help (lazy azz wizards). Tried reinstalling the program and a bunch of other stuff. At least the drive was now showing up in the BIOS.
I finally googled how to do this manually in Windows 10 and watched a youtube video that showed me how. It's not hard once you know where to go and what to do. Ok, the new Samsung 850 EVO 2.5" SATA SSD is now installed in the tower and working (initialized, partitioned, and formatted). Here's a photo, although there isn't much to see. The new SSD is the bottom drive and above it is an old fashion 1TB Seagate HDD.
Up next, I will attempt to benchmark the new SATA SSD while monitoring and recording drive temp. I hope to test whether the provided fan works at lowering temps or not.
Continued...
Overview:
***time passes***
Continued...
Continued...
