- Nov 16, 2010
- Netherlands
[Benchmark & Review] Arctic Accelero Xtreme 7970 DCACO-V15G300-BL
I always had high temps last few weeks. I cleaned the cooler of it. Had no dust in it that could affect the temps so much so ordered a Arctic Accelero Xtreme 7970 DCACO-V15G300-BL yesterday.
It had a lot of good reviews so should be good to go.
Review and benchmark will be here in a day or 3
Benchmark:
- Stock clocks
- CCC Auto fan speed
- Furmark burn in 99% load
- Antec 902 all case fans @ 50%
Review so far:
Images:
Cable management looks terrible but it isn't that bad.
Benchmark:
- Stock clocks
Review so far:
- Image/Video
- See pictures below - Product Description
- Arctic Accelero Xtreme 7970 DCACO-V15G300-BL - Description
- Great VGA cooler. It is really virtually silent, even at 2000rpm! If you compare it with the stock cooler. - Proof
- Check the images below - Negatives
- It's a bit big. It didn't fit in my case i had to put my SSD 2 racks up in the harddrive bay. It was all about millimeters. But it did fit in my Antec 902. - Keyword Phrase
- Great product if you are looking for a better cooler than the stock one, go get this one. But make sure it does fit your case! Because its large.
Images:
