- Nov 1, 2001
- New Iberia, LA
No, they aren't worth $10 more than the Gentle Typhoon fans. They are good fans, but I wouldn't classify them as any better than the GT fans. And for case fan usage you might want to go with the AP-14 fans instead of the AP-15 versions. A little less cfm and a little quieter also, and still move a decent amount of air. But really, either should be great for case fan use. And don't turn your nose up at the Thermalright fans or any Scythe S-Flex fans if you can find them for significantly cheaper than the GT fans. The bearing package in them is at least as durable as in the GT And Noctua fans and are very well made. Scythe no longer sells the S-Flex fans but you can still find them in the supply chain at times. I'm about 98% sure that Scythe and Thermalright used the same OEM for the S-Flex and TR-FDB fans. For the S-Flex series, I would say to look for the SFF21E or SFF21D fans, which would correspond with the TR-FDB-1300 and TR-FDB-1000 respectively.
