Ehh... there is much to upgrade to really... just ahex core from AMD and either a 790 board that supports it, or 890.
The FX series chipsets are the best for overclocking. The 790FX is older but less expensive, the 890FX is newer and usually has more features. The 890FX will also handle an X6 better if you plan to upgrade the CPU in the future. Here are a few choices ...Iam thinking to spend 150-200 usd in a good mother.
Whats a good brand for OCing?
790, 890 or wait for next model?
thanks
Uh, I think he's talking about the motherboard, since he mentioned that in both posts, not the CPU ...I would check the manufacturers website to see if you only need a bios flash to support a hex. If so, you only should upgrade to a hex core.
The 790GX isn't the best chipset out there but it's not bad, either. As mentioned above the FX series is the best and below that, if you can find them, is the X series - both better OC'ers than the GX (= with IGP) chipsets ...Sorry man, I just read the title.. Best Brand/CHIP model for overclocking. CHIPSET was the word he was looking for I believe.
I read and saw 'mother' but wondered why anyone would upgrade from a 790GX if it already supports a hex (like my second post basically said).
My bad though, I apparently missed it.
The 790GX isn't the best chipset out there at all. As mentioned above the FX series is the best and below that, if you can find them, is the X series - both better OC'ers than the GX (= with IGP) chipsets ...
Don't know why anyone would suggest a GX chipset for OC'ing unless the IGP was requested or they were looking for budget boards, though many GXs aren't budget.Hmm, I wonder why people in AMD threads I participate in suggest the 790g/fx chipsets with a hex then. I thought he was OK with that mobo... glad you swung by to save the day!
The FX boards typically have higher quality parts, which shows itself in better power delivery, and can clock higher if the HTRef is being used. Never seen a GX board that could run over ~260 MHz, and most can't go that high, while most (not all) FX boards will run 300 MHz or more. Beyond component quality I suspect the difference is because FX boards have more than 2 PCIe X16 slots so the minimum power requirements for the board are higher. Since most people don't use more than two slots that's just gravy.What are the relevant differences between GX and FX, other than IGP?
((We keep cross-posting - I edited my previous post but you slipped in between, again!)) I guess my wording was bad. (edited previous post)If on a budget, it seems as tho the GX based boards may not be so bad... Sno seemed fairly happy with the MSI 890GXM-G65, albeit voltage options were limited (coming in bios update according to msi) and core unlocking is not supported:
http://www.overclockers.com/msi-890gxmg65-review/
He hit 3.7Ghz on that.
Also experienced good results with the MSI 760GM-E51:
http://www.overclockers.com/amd-core-unlocking-msi-easier/
He hit 3.6Ghz on that one. Both boards he really liked the bios also... For daily drivers I'm not sure it makes a difference which chipset suits your fancy... But if you want to have the option of running something extreme, it is the 890FX chipsets I've seen the best results from.
Just to muddy the waters, my dad's asus m4a78t-e (790gx) boots at 330htref on air.
We had the same problem in another thread as well ...Also, the board he listed is different from the one in the signature...
Instead of a hex core just light your next paycheck on fire and move on. Why people insist on buying a hex core when most apps dont even support quad cores is beyond me.
So I guess the most appropriate question to ask the OP is what does he need to do that his current motherboard isnt doing?
