Well because it is a willy, I'd say just keep the stock HSF because it will not overclock much at all compared to the Northwoods. Just get rid of the thermal pad and use some Arctic Silver III.
Hmm..., these are approximate
$14 tubing (Tygon)
$25 Heatercore
$100 1140gph pump (it's a whopper)
home made shroud $0
Home made res $5
Home made waterblock $? (Various models made)
I had the fans $0
You could settle for a $50 pump and a $50 waterblock to get a setup goin for yourself in that price range if you have fans and make your own shroud and resevoir.
It was a labor of love
It would not be hard for you to do with all the help you can get from around here.
idle temperatures are allmost same but on pure torture Alpha keeps my p4 over 10c cooler than stock... and i'm using small and quiet 80x80 instead of Delta(delta would be way better) =) one guy here overclocked his 1,6A @ 3,19 with Alpha and delta
