Hi guys,
I'm looking for a good cooling solution to get that little bit extra bang out of my otherwise aging computer. When I initially built the system I bought the Arctic Cooling Freezer Extreme Rev2 to help keep the temperatures down.
After overclocking my Phenom II x6 1050t and running prime95 my cpu would hit 65C in seconds and then go higher and crash. I pulled off the cooler and noticed the cpu was literally covered in dust, even dust under the sides and just about every rung on the cooler was littered with dust, plus the thermal paste needed reapplying (I used to have a negative air pressure). Needless to say it's much cooler now.
But I want to go further, atm I can run prime95 for 30mins and the temp will slowly reach and max out at 60C (I am in an air conditioned room). First off, what can I do to decrease the temperature further.
Second problem, I live in Australia, it is so goddamn hot here, (it's midnight and the air con is on). In a few days temperatures will reach 33C/91F and 70% humidity (it's not even summer yet). I have temporarily moved my PC to the lounge (my mother is aghast) to be in the air con, but I can't keep it out here forever and we can't afford to run the air con forever. In summer it will get even hotter and my computer will also get hotter with it.
What can I do to combat this heat. My budget isn't huge but I am more than willing to save if the need be. Noise means nothing to me, I have never cared about a noisy computer.
CPU-Z Specs I have 3 intake fans, 2 outtake fans and the Cooler fan. It is a little cramped inside the case.
