Relentless_Engr
- Aug 19, 2014
So im trying to get everything planned for a new 6 monitor build. (I've put together a couple smaller systems already)
I want a 2x3 monitor set up that will mostly be used for CAD work, FEA and general computing, but I also want to be able to disable the top 3 monitors and game with the bottom 1x3 monitor row as a normal 3 monitor set up.
I cant seem to find a strait answer anywhere if this can be done (mainly how to do a good 6 monitor set up). I really like the Asus posiden GTX 780 cards but from what I can tell an AMD card will be better for this.
So is it possible to set up what I'm describing? And if so how would I go about doing it?
Oh yeah, what ever cards I end up getting will be water cooled, budget isnt really an issue but i would like to try ro keep it under $1200, and the rest of my system will be:
Mobo: Asus rampage IV black LG A 2011
CPU: Intel i7 4930k (water cooled)
Ram: g.skill trident X
Custom built case
Windows 7
PSU will be picked once I know my GPU config.
Custom built case
Windows 7
