I am looking for suggestions on the best best combination of a case and cooler for an i7 2600K OC'd to 5 Ghz (or as close to that as I can get). This is for video so there will be lots of heat- most cores and threads will be used most of the time with applications that implement multithreading. I don't want it to sound like a cyclone either so a solution that is quiet is preferred.
I am looking for something off the rack, not a custimized water block.
I am open to air and water. I have noticed that some of the big water coolers don't fit in the case so easy (like the Corsair Hydro H100). And some of the big air coolers also have a tough time fitting cases. That is why I would also like to know what case you would recommend for the cooler- midsize case like the Haf 912 or Corsair 600T (which now comes with fans on the side panel).
Anyway, let me know what you recommend.
