Yes, well Blu-Rays are a lot bigger than DVDs but not that much faster. 1x for Blu-Ray is defined as 4.29 MB/s (about three times faster than a DVD).Well I decided to just buy PowerDVD11 to play back th blurays.
Just ripping StarTrek (2009).....Ripping speed seems rather low (around 10 - 13MB's) This is going to take alot longer than ripping my DVD's
That doesn't make any sense. Run it through Handbrake with a quality setting of 22 and you will not be able to tell the difference quality wise. I tested this for myself using different compression levels, as well. You are literally wasting space.
That is the speed I was getting as well. It isn't too bad if you are doing something else at the same time.Just ripping StarTrek (2009).....Ripping speed seems rather low (around 10 - 13MB's) This is going to take alot longer than ripping my DVD's
Compressing the video took around an hour per bluray movie and half that for a DVD using the system in my signature. I even have 14 TB of space on my server and I compress videos. No use in wasting the space I have. Depending on the movie, the end file can be 2-10 GB in size. Cell shaded movies (like Disney ones) compress down to 2 GB or so and ones with a lot of action (Avatar, for example) are on the high end.I literally believe you but how long does it take to run through handbrake? I'm guessing a good deal of time. How much space are you saving at setting of 22, percentage wise. A typical Blu-Ray is around 48GB(though some are much less)
I'm guessing the time and effort isn't worth the value of the HDD space to me given how ridiculously cheap storage is. Those brand new cutting edge 4TB drives are $320.
JMD,
An uncompressed rip in IMGburn for a 48GB disc takes me about an hour.
Total noob here. But how can you read it off the iso? Don't iso' have to be written to a cd/DVD/bluray to be usable?
I am hoping to get into this because I have the entire stargate collection on DVD and want to have it all playable on my hardrive.
And how's PowerDVD11 going? Can you play ALL your Blu-rays?
I downloaded PowerDVD11 and ArcSoft TMT a long time ago to try the Blu-ray playback function and they didn't work for me. Had some problems playing some BD discs (I think they were from Warner, because of somekind of DRM).
You are ripping them with MakeMKV first, right? If so, can VLC play the uncompressed video?
What version of Handbrake are you running and on what OS? I found the Linux version of Handbrake to be far superior to the Windows one.
Try to grab the nightly release off their site. I had some lockup issues when using the Windows version.
HDDs are still cheap enough ...
