Hey all,
I have 15 or so different hard drives I sub in & out of my workstation. I have 4 extra SATA drives on a SATA expansion card in my workstation, an external unit that holds 4 drives, and a bunch of random single unit external enclosures. All are USB2 but the drives are an assortment of IDE & SATA 1&2.
I have had increasing problems lately and cannot even see them all now. I am using a Belkin 7-port hub and suspect that is a partial culprit since the single drives can be hooked up and seen fine on my wife's PC. This hub causes my PC to take over 2 hours to boot when it is plugged in, and still only sees half the drives plugged into it. I replaced it with a new identical one because I had the old one for 2 years and it worked great, but I'm getting the same results. I have tried changing variables such as UDMA6 --> 5 on some drives etc. but it hasn't helped.
Punchline: Does anyone have experience with a decent 7+ port USB hub that will see just about anything I plug in to it? Or if you have any other ideas or comments on my setup I'm all ears. Many thanks!
