I'm going to be trying my first custom loop. All hardline tubing. Single 280 mm Corsair radiator mounted in the front with two QL140 fans. These are low speed fancy RGB 140mm fans that only run at 1250 RPM. It's going in a NZXT Elite H510 case. I'll be cooling a 2080Ti and 9700k, both being overclocked so I suspect it's going to pump out a ton of heat. The question is whether I should pull air from in the case and have it exhaust out the front or take clean air in from outside and pump the heat into the case. Obviously pumping in 500w of heat into the case is not the most ideal, but I am thinking that if I try to take the air from inside the case and pump that through the radiator, it's going to result in increased coolent temp because the air coming into the radiator will hotter from inside the case than outside.
What do you think?
What do you think?
