- Oct 28, 2017
https://eandt.theiet.org/content/ar...xposes-passwords-and-web-activity-to-hackers/
Graphics processing units (GPUs), a core component of all computers, have been shown to be vulnerable to cyber-attacks that could give assailants access to web activity, passwords and entry into cloud-based applications.
Click!
Computer scientists at the University of California reverse-engineered an Nvidia GPU to demonstrate three attacks on both graphics and computational stacks, as well as across them.
The team believes these are the first reported general side-channel attacks on GPUs.
All three attacks require the victim to first acquire a malicious program embedded in a downloaded program that is designed to spy on the victim’s computer.
Web browsers use GPUs to render graphics on desktops, laptops, and smart phones. GPUs are also used to accelerate applications on the cloud and data centres. Web graphics can expose user information and activity. Computational workloads enhanced by the GPU include applications with sensitive data or algorithms that might be exposed by the new attacks.
GPUs are usually programmed using application programming interfaces, or APIs, such as OpenGL. OpenGL is accessible by any application on a desktop with user-level privileges, making all attacks practical on a desktop. Since desktop or laptop machines by default come with the graphics libraries and drivers installed, the attack can be implemented easily using graphics APIs.
The first attack tracks user activity on the web. When the victim opens the malicious app, it uses OpenGL to create a spy to infer the behaviour of the browser as it uses the GPU.
Click!
Every website has a unique trace in terms of GPU memory utilisation due to the different number of objects and different sizes of objects being rendered. This signal is consistent across loading the same website several times and is unaffected by caching.
The researchers monitored either GPU memory allocations over time or GPU performance counters and fed these features to a machine-learning-based classifier, achieving website fingerprinting with high accuracy. The spy can reliably obtain all allocation events to see what the user has been doing on the web.
In the second attack, the authors extracted user passwords. Each time the user types a character, the whole password textbox is uploaded to GPU as a texture to be rendered. Monitoring the interval time of consecutive memory allocation events leaked the number of password characters and inter-keystroke timing, well-established techniques for learning passwords.
The third attack targets a computational application in the cloud. The attacker launches a malicious computational workload on the GPU which operates alongside the victim’s application. Depending on neural network parameters, the intensity and pattern of contention on the cache, memory and functional units differ over time, creating measurable leakage. The attacker uses machine learning-based classification on performance counter traces to extract the victim’s secret neural network structure, such as number of neurons in a specific layer of a deep neural network.
The researchers reported their findings to Nvidia, who responded that they intend to publish a patch that offers system administrators the option to disable access to performance counters from user-level processes. They also shared a draft of the paper with the AMD and Intel security teams to enable them to evaluate their GPUs with respect to such vulnerabilities.
In January Google security researchers discovered a major flaw in Intel’s processor chips that affected all platforms and could see hackers gain access to confidential information.
Click!
Click!
