- Feb 4, 2003
- Aldergroovey, BC
Sweet. I just switched my cooler to a 947U and I'm torture testing as we speak at FSB 210mHz. Not super high yet bit my die temp is only 29°C!
qbas said:Do any of you have any clue why i can't get high FSB's? Is it my memory that is holding me back? Is it the memory that i can't get FSB 200 to work on default Vcore?
tom10167 said:
Is that on any multiplier? How about voltage? I was having similar problems, but I've come to find that if I did about 100mhz overall increase each week, I can easily boost up the speed, I even lowered the voltage to 1.6V What BIOS'S have you tried?
flowrider said:Oh crap! I tried several times to flash to 2.1 but with no success. I flashed with Flashmenu and awdflash with no luck either way. I can't even get the computer to boot to windows. It hangs after updating escd and locks completely when it tries to boot the cdrom.
No luck for me. Back to 2.0!
Hoot said:
Similar results here. I can boot into Windows from my PATA drive and access my RAID0 SATA Raptors, but I can not boot into Windows on my RAID0 SATA Raptors, which I could do just fine with D20.
Back to D20 and everything is fine. Boots into Windows with either drive.
Hoot
flowrider said:Thanks hoot. Where can I get this d20 patched bios? I'm running into the same problem with the raid0 config.
xtern said:@qbas, its your memory holding you back. the m-tec stuff sucks big... well you know.
so that's why you struggle around 200fsb. I promise this is the reason, and I order you to get different ram.
i went thru all that bull, and then switched to adata, and now I'm at 228 and lovin' life again.
