Biostar a770e3 is boss!
hank123
With Yahweh in Colorado
I got this board a few weeks ago with a x2 250. Right now its running at 3.9 with a max voltage of 1.440. Ram seems to clock fine. Some dirt cheap D9JNM's running at 866 with 8-8-8-24-36 T1 in single channel @ 1.65V bios.
The one issue I did fine with this mobo is that when setting the ram voltage higher then 1.7 it drops it to 1.5 or so tell you reach the 1.8 1.85 range then it sets it correctly. I did find the voltage measuring point on the mobo and confirmed this with a voltage meter.
Ill update later and see if I can reach lower timing.
