If you need onboard video why don't you take a look at some boards with the AMD690G chipset. They have ATi 1250 GPU onboard I believe. Some also have HDMI.
The 560 A2+ is not a true AM2+ board in that it doesn't have split power planes, and it doesn't support HT3.0. It is however a great board for overclocking.
I believe they called it AM2+ because it supports AM2+ CPUs (shady I know) as should all AM2 board with a bios update. The 520 is a fine choice, as is the 7025/7050, the Gigabyte 690 S3H is also supposed to be pretty good.
The A2 in my option is good for someone planing on a Phenom soon or will drop in a Phenom, be happy with one video card until AM3 comes out. Overclocking will be limited by the lack of vreg control but the regs on it look pretty good for a solif board.
Hey guys, few things:
#1 - What is the stock vcore for Brisbane - is it 1.30v, or 1.35v??
#2 - I'm on the Biostar TForce 570 SLI, and I can't seem to get the CPU temp down right. I COMPLETELY HATE the overclocking/monitoring progs on the Biostar CD. Right now I'm using Clockgen for overclocking through windows (as the stock Biostar one started crashing the system b/c it keeps remembering latest settings, so when I change something in BIOS it doesn't agree). What should I use for CPU temp and other temp monitoring? I'm using SpeedFan and it has a billion things listed... such as:
Temp1: 127C
Temp2: 21C
Temp3: 12C
Temp: 39C
HD0: 23C
Temp1: 40C
Core: 4C
Core: 31C
Ambient: 0C
#3 - How high can HTT go? I'm at like 1150mhz now, and wondering if I should lower the HTT multi, or should I just raise HTT voltage?
#4 - I've got a set of OCZ 2GB Rev2 800mhz 4-4-4-15, and wondering what I should set ram voltage and chipset voltage to. I wanna go for 3ghz on CPU (which won't be much vcore cuz I can prime 6hrs p95 at 2.95ghz stock vcore), and approx. 450mhz 4-4-4 on the ram. I'm running the max (10.5x) divider on a 4000+ X2 Brisbane, but maybe I should go for 300x10 instead of 286x10.5
THANKS FOR ANYTHING. Of course I could figure this all out on my own, but I figured most of you have already done this and could save me valuable time. This machine is for my gf and so far it rocks.
The Biostar Utility, Speedfan, NextSensor, and a host of other temperature monitoring utilities. The hard part is figuring out which temperature represents your CPU temp.
Temp1: 127C
Temp2: 21C
Temp3: 12C
Temp: 39C
HD0: 23C
Temp1: 40C
Core: 4C
Core: 31C
Ambient: 0C
I guess I'll have to go with the sensor I listed in my post a few posts up that says this in speedfan
(in white bold):
Now here's my question... does each one represent a CORE? Does AMD have separate temps for each CORE like INTEL does, or just one temp for CPU??
Temp1: 127C
Temp2: 21C
Temp3: 12C
Temp: 39C
HD0: 23C
Temp1: 40C
Core: 4C
Core: 31C
Ambient: 0C
Yea, there is one for each core.
For temps I loaded up the Biostar utility and compared those temps to speedfan to figure out which is which. The Biostar utility was the ONLY temp monitor that showed the temps properly. I ended up using offsets to the temps in speedfan to get them right.
1) I think 1.25
2) I only OC'ed through the BIOS. It took a bit more time, but it turned out to be the only good way to OC this board.
3) funnyperson1 answered
4) " "
I hate the Biostar utility. I used it when I was on a 667 ram divider, then when I lowered my FSB in bios and booted with a safe 800 ram divider, everything was fine... as soon as I load the Biostar utility the system FREEZES... EVERY SINGLE TIME, no matter how much i ease up the settings. I guess the utility remembers the last thing you did and I do NOT like that...
1) You sure 1.25? I thought it was 1.30...
2) Clockgen is working out awesomely... I like clockgen b/c I can OC remotely from work (yes, I'm bad like that lol)... and also I don't have to keep rebooting. I get a lot more done in less time. I go to BIOS to change voltages and multipliers, but clockgen helps a lot. I used it on my old DFI NF4 and kicked butt with it
4) " "??? Does that mean what funnyperson said? I don't have D9s. They are OCZ Plat Rev2 800mhz 4-4-4-15 sticks. I think they are PROMOS, but who knows... I don't know anything but that Crucial ballistix are all D9GMH (my rig I use the 8000 tracers)... this rig is, remember, for my gf, so I wanted to keep it on a budget. I picked up the plats for like $30-35 AR.
I just wanna know what voltage I could run the plats at, and what is too much or too little for them. I'm not sure if they OC better with higher voltages or not, so that's why I ask. I'd set them to 2.1 or 2.2v if they will do better and if they won't burn up at that.
I can run approx. 430-440mhz 4-4-4-15 at 2.05v, but I can't seem to go much higher with 5-5-5... my goal is to do 500mhz 5-5-5, but I don't wanna waste centuries doing so. Right now I gave her the rig at these settings, 20h prime stable:
286fsb x 10.5 = 3004mhz, 1.35vcore
667 divider 429mhz 4-4-4-15, 2.05vdimm
I think 3ghz at 1.35vcore on a CoolerMaster HyperX is perfect for daily usage, but wouldn't mind increasing ram by going for 5-5-5...
