Hey guys,
First time posting here, I have recently completed my first pc build ever, (open watercooling loop) and it actually didn't leak! I felt hugely successful given that this was my entry into building my first machine. What did happen though, was that I ended up with a bit of corrosion (brown gunk) building up in my loop after about 2 months of usage. Typical full load temps floated around 35-40c. Never went above 41c.
Relevant specs:
Case: lian li 011D
Bitspower gpu and cpu blocks
Bitspower fittings 14mm
Bitspower touchaqua sedna front distro plate with pwm pump
Petg hardline 14mm
XSPC rx360 and ex360 rads
Gpu 2080 super
Cpu i7 9700k
I suspect the brown stuff might have been the fluid. i used distilled water and a biocide/inhibitor (primochill utopia), but I can't be sure.
In any event, I have done an entire teardown, cleaned all fittings, rinsed radiators, etc. I was going to use a premix this time, and decided on xspc ec6 clear.
My attempt at reassembly was successful, save for the fact that my front panel distro plate now leaks after disassembling and reassembling it for cleaning. I've tried multiple times to reseat the o-rings, cranked down the Allen screws, slightly loosened em, etc. but it always seems to leak. Mind you this is a very very slight seeping leak, and always happens near the pump inlet at the base of the res.
I've searched the web a bit for how to properly reseat and reassemble a distro plate, but can't seem to find any good info. Am I missing something here? Do I need to apply a sealant to the o-rings? I'm assuming the seal between all the waterways is produced from essentially compressing the o rings between the two plates. The sheer amount of screws also made me feel like I needed to follow a torquing pattern, so I was always jumping across the plate as I gradually tightened to avoid over compressing unevenly.
I should also mention that I noticed that after disassembling, the thicker backing plate of the distro was warped upwards very very slightly, indicating that it might have been either over pressurized or vacummed from thermal exchanging. Is this normal? Admittedly I didn't install the included air valve fitting at the top of my res. instead, I just used a standard stop fitting plug. Speaking of this fitting, I'm also confused as to what this included air valve fitting does. I know you can press the air relief plug button to bleed air out. Aside from this, does work passively as the system cools and attempts to produce a vacuum condition? In either case, I'm worried that the warping is now causing the improper sealing of the distro.
Ive tried to find information regarding distro plate disassembly and maintenance, and haven't found much. Do I need to replace or get a new distro? I don't mind getting one, might try a side mount one instead since it's a smaller surface area and would be less prone to warping. Any help appreciated, thanks so much for reading. Included a Pic of the build and closeup of the leak for reference. Thanks again!
Relevant specs:
Case: lian li 011D
Petg hardline 14mm
Gpu 2080 super
Cpu i7 9700k
