Ok for starters I have been on water for about 3 years now, but just never got around to switching out to a better block that I knew I needed due to limitations on time from work and kid. Fast forward to two days ago and the acytel top of my block cracked and leaked water onto my gpu. I cleaned my gpu with contact cleaner, filled my res, and dropped a plastic bowl/towel around leak to make sure all was ok. After makeing sure I was aok I replaced towels with new and pulled the plug until I could get a new setup. (been researching since). This however was not good enough for the little woman in my life as I got home from work today to find her sitting on the couch and the first words out of her mouth was I think I broke your computer.... Things just got more expensive.
So anyway I'm rebuilding a med. build while I wait for ivy bridge to drop (which was.to be my next build)
Being that I want to keep it reasonable I am thinking about the maximus gene IV , but have never dealt with matx and do not know if it will meet the space requirements for the waterblock I am planning on getting.
Here is what my thoughts are. (Only thing I am keeping from old loop is a swiftech 120 rad and possibly a 120x3 but will have have to see if its worth saving)
Culex Kryos HF
Swiftech mpc655 (to replace the cheap thermaltake pump that may have been running dry)
Phyoba balancer 250
Some koolance qdc vl3n for the water block
Silver coil (IandH)
Copper sulfat (IandH)
Primochill tubing. 1/2" from pump to block. 3/8 from block to rad (this could change as I had only been running the 3/8 to match the fittings on my rads and on maximus extreme waterblock heatsink I had put on my rampage formula)
Need to get a new 120x3 rad as well as I took out a bit of rage on it after my little lady left...
So does anyone have experience with matx and available space? (specifically on that board)
Also I will be cooling some gpu in my future ivy build so any suggestions on parts I may change now to avoid future cost would be helpful.
I am reading up on all the latest info that I can, but as I'm down the whole rig now any advice that would speed up the process would be great. Thanks in advance guys.
Culex Kryos HF
Phyoba balancer 250
Silver coil (IandH)
