- Jul 27, 2004
Just cut and fitted a 120mm blowhole using a antec fan at 7volts its shifts alot of air.
Running prime on heat test and using speenfans temp graphic i waited for temps to be stable cpu was 49c and sys was 30c with the blowhole blocked of with a heavy book.
Removed the book so the blowhole was in operation and with in 30secs my sys temps raised 2c and in 2 mins my cpu raised 3c.
I guess its conflicting with the 2 80mm exhuast fans i have at the rear of case.
Might swap the fan around so its a suckhole and check load temps wish i had not bothered completerly stripping my case a jigsawing the hole which is really easy on a 120mm did it spot on.
