- Dec 9, 2002
Does that fix the issue of CUDA only ignoring CPU issue? That is use all CPU cores + GPU at once?
I take it that it can do the regular MB work units + the CUDA work too, eagle? If so, I might try this on my main rig, which has an 8800GTS in it. But I will see how it works out for you first for a little bit. Please keep us informed on any problems with it.
Yeah, sure will once I get some time to get it up and running. I'll probably be going to get some new rims on my car today.
How do you have reporting set up under Advanced/Preferences/Network Usage ...?I upgraded all my BOINC instances to 6.6.4, and they're not reporting results like the previous version. Every morning I have lots of tasks sitting at 100%. I can manually update and they report fine. I have "network activity always available" selected. The prior version didn't do this. Any ideas? Oh, and I'm running Rosetta, btw.
