- Feb 2, 2004
- Winnipeg, Canada
when i try to boot normally, it gets to the boot screen and then it gives me a BSOD that says "STOP: 0x0000008E (0xc0000005,0x03020100,0xf87854f0,0x00000000).
i can get into safe mode but thats it.
the first time this happened was when i was using bootvis, i didnt change any of the settings, i just set it to do a reboot and then this happened. i am thinking that some of the boot files must be corrupted. it boots into safe mode just fine, which coincidently does not use the boot screen. i will try a repair install of winxp but i was wondering if the repair install will do anything to files or the registry? i am also scanning for a virus right now just to be sure. any help would be appreciated. thanks
