Hi all,
I’m having some serious problems getting my memory to work at the advertised speed in my new setup and thus wanted to get your opinion. But first the relevant hardware components:
CPU: AMD Ryzen 3900x (not overclocked)
Motherboard: Gigabyte x570 Aorus Master (F6 firmware)
RAM: G.SKILL F4-3200C14Q-64GTZ — https://www.gskill.com/product/165/...DDR4-3200MHz-CL14-14-14-34-1.35V64GB-(4x16GB)
Problem description:
Whenever I populate all 4 memory slots on the motherboard and attempt to enable XMP (or set the relevant timings to achieve 3200 Mhz manually) I get something like 50% success of booting the system. When it boots, it runs perfectly fine, I can stress test it and there are no issues. However, when it doesn’t I get a red light on the VGA on my motherboard (for some reason) and it stays there indefinitely.
If I remove the 2 slots, everything works perfectly fine, I get 3200 Mhz and boot success is 100%. However, before buying this memory I checked the QVL of both the memory and motherboard site (https://download.gigabyte.eu/FileList/Memory/mb_memory_x570-aorus-master_matisse_190812.pdf) where it’s stated that there is 4 memory slot support and XMP can be enabled. Thus, I’m very confused on why it would work half of the time I power on my PC. If this setup with the 4 DIMMs wasn’t supported, would it be able to even boot a single time?
My question to you, smart people, is whether you have some suggestion on whether this could be a CPU limitation, motherboard limitation, memory issue or a combination of all of the above. My impression would be that since the system can actually boot up sometimes, the problem could potentially be fixed with some firmware update in the future ?
Many thanks for your time and help!
