- Mar 14, 2005
- Trenton
If you want to save a bit of money and have a decent fan, get a 92mm Vantec Tornado and adjust it with a fan controller to your preferences if you find it too loud.
Yuriman said:I would go with one of the fans below. They've treated me well. You need an 80mm, right?
http://www.sidewindercomputers.com/pa80ulhisp.html
http://www.sidewindercomputers.com/de80trblhisp.html
http://www.sidewindercomputers.com/de80tfexhisp.html
http://www.sidewindercomputers.com/sadedcpeace8.html <- you can find a better price
I've owned all of the above fans (lower speed models) and have been very happy with them. I'm using a Sanyo Denki in my side panel, and a Panaflo in the back of my case. The Deltas, being 38mm, will have higher pressure and would do very well on a heatsink. They will probably produce a bit more motor noise per CFM than the Panaflo and SD though.
Keep in mind that nothing's going to beat that because of the way Tt inflates their specs. Any fan from a good manufacturer with similar airflow will almost certainly be quieter.Can you post why that's better than
20.55 CFM at 1300 rpm 17 dB
variable all the way to
75.7 CFM at 4800 rpm 48 dB
(Smart Fan 2)
