Can you elaborate on that a bit? I've stuffed drives WAY fuller than 15% free space available without error...
I didn't mention this before, but it took me 3 days and 5 tries of installing windows in order for it to properly work on these new drives in RAID0
But the last 3 BSODs my temps were around 25-35max. I dont know, I am not expert, I have been looking into watercooling, just is going to be expensive because I am going to need a new case, plus the smaller block shaped coolers don't cool as well as my current setup (according to other forums and reviews with my same CPU with OC)Sure!
I agree on the high temps as well. From my experience, anything over 50c with an overclock will eventually error.
No, RAID. It will not boot in AHCI. I know everyone told me to use AHCI, but again, doesnt boot and my two IT friends dont know why. So I left it in RAID.So you eventually found the right driver and is set up in AHCI mode correct?
The error was 0xA.
Well, prime does report errors when I dont have proper voltage. But I will do what you said and check those settings and run it again.That error code is typical AMD core instability and CPU instability may also cause you to get an error message about being unable to initialize or report an "internal error" and etc.
(Also, Windows 95 and Windows 98 will report an "illegal operation", too.)
It can happen any time when the CPU is real unstable.
And Prime95 requires settings to be changed:
The defaults aren't sufficient!
You must enable round off checking on one of the menus, by checking it and the same with sum checking.
Likely why Prime95 reported nothing!
Late versions of Prime95 stubbornly have those disabled by default.
Like I said, only when I have the wrong voltage set.Ahh there it is....Cpu errors. Unstable.
While running Prime95:
Now that I have said that, lets totally contradict myself and say that I did get a fatal error, I didn't give me an error message, but I think it said expected less than 0.4, received 0.5. Worker stopped, on worker #5. This was at 4.4Ghz, and I don't know what that means, but I think it could have to do with heat, my room is hotter than normal right now and my temps got up to 65C. (this was also after I set the SUM error checking and Round off checking)
I went down to 4.2Ghz, temps maxed out at 56C, still running now going on an hour with no errors. I will update if anything changes.
Still don't believe this has anything to do with ntoskrnl.exe error.
Download BlueScreenView v1.47 to find out which driver is causing the errors...
http://www.nirsoft.net/utils/blue_screen_view.html
... and run a chkdsk /f on the root volume.
That just tells us a crash took place in the Windows kernel. What driver is shown in BSV as causing the error? And what were the results of running a chkdsk /f on the root volume?jproductions said:I am getting the ntoskrnl.exe error.
I ran disk check
About to burn the memtest86+ and see if that gives me any errors.
