Hiya guys I've been looking at getting some RAM for my new build, just wanted some opinions from you guys before I buy.
I've already purchased:
i5 4670K CPU
AsRock Z87E-ITX Motherboard
(The Z87e-itx above supports dual channel DDR3 up to 2933+(OC) )
For the moment im going to be running stock, but as soon as i get my cooling sorted I hope to overclock my CPU at some point, so I'm kind of looking for the best or recommended budget ram which might be best for my scenario.
I've been looking at purchasing the following ram, i.e the cheapest I can find below. Can anyone tell me if the the following would be good enough for the job:
- Crucial BLT2CP8G3D1608DT1TX0CEU 16GB (2x 8GB) Ballistix Tactical Memory
1600Mhz
- Patriot 16GB Viper 3 Dual Channel Black Mamba Memory Kit - Black (PV316G160C9K) 1600Mhz
-G.Skill 16GB (2x 8GB) Dual Channel Ares Series Memory Kit (DDR3 1333, 9-9-9-24, 1.5v, Intel XMP Extreme Memory... 1600mhz
- Crucial BLT2CP8G3D1608DT2TXR... Tracer 16GB kit (8GBx2), Ballistix Smart Tracer 240-pin DIMM, DDR3 PC3-12800...
I'm ultimately going to be putting them in a nice little Bitfenix Prodigy mini-itx case:
I just want to know which of those memory modules you guys would go with... is 1600Mhz sufficient for my 4670k i5 where over clocking is concerned, I see Intel recommends DDR3-1333/1600..any ideas please; will i see any gains buying higher hertz RAM?
i5 4670K CPU
1600Mhz
