- Oct 5, 2010
- California
- Thread Starter
- #21
How did you assemble the two acrylic plates at the bottom? Are they screwed or glued together or just put together "loose" for easy takeout?
I had them cut just a tad longer then what I needed so that they would sit in there snug. I was going to use some crazy acrylic clue...and then realized if I were to get new parts, or change out something...i would then have to break the box...so they are sitting in there "loose" but "not"
