- Sep 25, 2015
Edit 11/05/2018: Added Index
ADT Pulse - First Look:
- The iPhone App: https://www.overclockers.com/forums/showthread.php/782809-Build-Log-Home-Automation
- The Web Interface: https://www.overclockers.com/forums...e-Automation?p=8020444&viewfull=1#post8020444
Installing the First Round of Z-Wave Switches:
https://www.overclockers.com/forums...e-Automation?p=8019771&viewfull=1#post8019771
Bringing the SmartThings Hub into the Equation:
https://www.overclockers.com/forums...e-Automation?p=8021549&viewfull=1#post8021549
SmartThings and WebCoRE...YES!:
https://www.overclockers.com/forums...e-Automation?p=8021766&viewfull=1#post8021766
VERA Sucks:
https://www.overclockers.com/forums...e-Automation?p=8022728&viewfull=1#post8022728
Bringing ZigBee into the Mix...and a Talking House:
https://www.overclockers.com/forums...e-Automation?p=8025416&viewfull=1#post8025416
Success Story - A/C Leak Pan Full...House Notified Me:
https://www.overclockers.com/forums...e-Automation?p=8078973&viewfull=1#post8078973
Updated some Lighting to LED:
https://www.overclockers.com/forums...e-Automation?p=8019206&viewfull=1#post8019206
Moved from SmartThings/ADT Pulse Combo to Hubitat:
https://www.overclockers.com/forums...ild-Log-Home-Automation?p=8162294#post8162294
Welp - after playing around with Alexa and some WiFi enabled WeMo switches and plugs, I decided to go all-in on home automation.
It's nice being able to turn lights, ceiling fans, pool equipment, etc on and off from anywhere.
The biggest challenge with this is that the industry is still fragmented. This device doesn't necessarily talk with that device. You can get bridging hubs and use IFTTT to bring stuff together...but IFTTT sometimes has delays, and bringing everything into one app for your phone is still a bit of a challenge.
I did some research, and almost went with these Wink Relays for in-house control pads:
https://www.amazon.com/gp/aw/d/B00M...words=wink&dpPl=1&dpID=41x4auc8rqL&ref=plSrch
But, they don't necessarily interface with all devices. And they have no plan to integrate with WeMo devices.
Z-Wave has been adopted by big companies (like GE), so I think this is the best option.
Now, if you bring in a security system, the last thing you want is to have yet another app and control panel for this.
The best DIY solution I found was from Protect America. A decent solution, but all of the zones interconnect wirelessly...which means batteries. Even if you have a house like mine with all wired door and window contacts, they can't interfaces. And, when you add on the monitoring service...they are about the same price as ADT.
My current system is ADT, so after talking with the agent that just left my house, I'm going all in with ADT Pulse.
So, step 1 gets installed as an upgrade to my existing ADT system:
- cellular backup monitoring (if you just use a land line, the system can easily be defeated)
- automatic door locks (Z-Wave)
- automatic garage doors (Z-Wave)
- 3 infrared security cameras
- touch screen control pads
- Alexa integration
The touch screen keypads have full control over all security zones, smoke detectors, security cameras, and Z-Wave devices.
Also, the ADT app has the same functionality as the touch screen keypads.
The ADT guy will install the system on Wednesday to complete step 1.
Step 2 (me):
- Replace existing WeMo WiFi switches and plugs with GE Z-Wave switches and plugs.
- The GE devices are cool as they let you do 2-way, 3-way, etc smart switches (one of the few that does).
- Add Z-Wave devices into ADT Z-Wave network for control.
- The WeMo switches are great if you just want WiFi.
Step 2 (me):
- Replace 2 house thermostats with Z-Wave thermostats (Honeywell has best) or Nest thermostats.
- Add thermostats into ADT network for control.
Step 3 (me):
- Add in Z-wave dimmers.
- Add in Z-wave LED RGB bulbs
In parallel with this, I'm also replacing the flood lighting throughout the house with LED devices that fit into the existing 6" cans...I'll post as I do this.
VERA Sucks:
- Alexa integration
Step 2 (me):
Step 2 (me):
Step 3 (me):
