Major update! Upgraded to a 4770K, Maximus VI Gene, and a GTX780! Pics below.
GTX 780! This is the EVGA SC edition.
Naked:
And here's the underside of the cooler, for reference:
All clean!
Took off the CPU waterblock to find this. Gross. I made the mistake of using CL Liquid Ultra...this stuff will NOT come off once solid. This was after several minutes of rubbing with qtips, paper towels, and rubbing alcohol. I think I'm going to have to find an abrasive pad, like a sponge or something, to get this crap off.
Ready to go!
Problem: The new design of the GPU waterblock completely messes up my loop flow. This was my first attempt at a new tubing arrangement...but it was super leaky. The 45 degree rotaries are being torqued just a little and are leaking at the joint again.
Closeup of the problem area:
Final tubing design. Not elegant, but it works! mATX is definitely a challenge for watercooling!
