Hello everyone. I have been working on this beast for the last few days and thought people might want to see this. This will be my new primary PC for my office and will be finishing it over the next week or so. I am have some cool things planned for it, including some 3D printed mods for the TT Core P5 open air case. Here is the part: (I still need to think up a good name.... "OverKill" would be fitting, but I am open to suggestions.)
This will also be my first custom water cooling loop, so I am open to any suggestions or thoughts if I am screwing anything up. Thanks!
Case: ThermalTake Core P5 Open Air
CPU: 6950X
MOBO: Asus X99 Deluxe II
MEM: 32GB Corsair Dominator Plat. 3000Mhz
GPU: (2) EVGA GTX 1080 Superclocked (SLI)
SSD-OS: Samsung 950Pro 512GB
SSD-Storage: (2) OCZ Trion 150 /RAID 0 (1TB)
PSU: Corsair HX1200i Digital PSU
WaterCooling:
CPU: EK X99 Monoblock
GPU: (2) EK-FC1080 GTX - Nickel w/ EK-FC serial-plexi terminal
RAD: Hardware Labs Black 480mm Ice SR2 White w/ White Fins (Corsair SP120 PWM Quiet Edition Fans)
RES: FrozenQ NovaCore Extreme - White w/ UV Cathode Inverter Kit
PUMP: EK-XTOP DDC 3.2 PWM Elite - Plexi
COOLANT: EK-Ekoolant EVO UV Blue
3mm LEDs in all plexi blocks.
RGB LED strips run from Mobo header.
I am going to try my luck at bending PETG for all the hard tubing. The rest of the fittings are EK-HDC 16mm G1/4 - nickel. I got the PETG from EK as well, figuring that would keep me from having any issue with tube dimension and fittings.
I am debating on adding a 240mm radiator along with the 480mm. (Decided to see what temps I get from the single 480mm first)
Here are a few pics of what I have together so far. I am waiting of EK to send me a few more parts and still have a few items coming from Performance PC.
The last picture is a 3D printed 120mm fan shroud. It is an experiment... hopefully it turns out and ends up in the build. I am also going to make some custom brackets for lighting and other fans.
CPU: 6950X
WaterCooling:
