Hey guys, the mobo on my ancient computer just bit the dust not too long ago. Last time I built a computer was probably 01-02', but I'm more than ready to get back with the times. I did a few hours of research (pretty minimal) and came up with this list. (Going to use my old case,hard drive, and monitor until I can afford to upgrade those also.)
CPU- $114.99
Intel Core i3-530 Clarkdale 2.93GHz 4MB L3 Cache LGA 1156 73W Dual-Core Desktop Processor BX80616I3530
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115222
PSU – $109.99
COOLER MASTER Silent Pro M700 RS-700-AMBA-D3 700W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171037
Mobo - $89.99
ASUS P7H55-M PRO LGA 1156 Intel H55 HDMI Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131623
Video – $149.99
MSI N250GTS TwinFrozr 1G OC GeForce GTS 250 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127445
RAM – $91.99
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL9D-4GBNQ
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
I was wondering if I could get more bang for my buck, it's totaling $557 dollars right now, not including heat sinks and fans I will have to buy. My budget was going to be around $600 total, but realistically it's probably going to be more around $650-700. Along with gaming, it will be used on my 42' flatscreen so HDMI is required, I was thinking maybe a different mobo that also has a HDMI port and more PCIxE ports so I can slap in another video card for SLI support in the future. Like I said, I've been out of the whole computer hardware scene and I'm just basing my choices on product reviews at this point it time, any input would be greatly appreciated! Thanks.
CPU- $114.99
PSU – $109.99
Mobo - $89.99
Video – $149.99
RAM – $91.99
