- Nov 11, 2002
- Arkansas
My attempt to make a bing high amp LT1083 based voltage regulator.
I first attempted this 8 years ago when I created this post. The project stalled after my first trial with two regulators (me thinking one was bad) likely damaged. That is what happens when you jump head first into a realm of ignorance. I'm pretty sure I had the pins wrong, so I don't know if they survived. When I have a minute, I will test and see if they are dead.
8 years later, I'm ready to get these together. I've added some stuff to what I bought below (all still in bags) and have way better tools and supplies than I did with my first attempts. However, I still have more projects than time, so hopefully I can give these more attention than I have.
I've noticed that there have been some changes in the diagram from my original in 2010. I need to make sure I still have whats needed.
One disappointing aspect of all of this is the now prevalent source of non-LT 1083s lol. It looks like its cheaper to buy about a couple assembled rectified controllers based on reproduced 1083s for what I paid for 4 LT1083CP pieces salvaged from a Motorola radio. However, I do not need the bridge or the capacitance of those commonly available. I still need what bing's design provides and still intend to use it in the same application.
My goals are slightly different. Before, I was looking for a solution to start a 230CFM 12V Delta fan and run it at its minimum speed allowed. That fan was rated at 3A, but I never tested it. I might dig it out and play with it, but I do not really want to hear that fan again... Now I will be powering multiple lower amperage fans. With 7.5A to play with, I could get any number of fans ranging from 200mA ~ 1A in multiple arrays. I can also isolate each circuit, if I still have four good regulators. These are going in a custom rack cabinet that has a 12V common rail I use to power whatever, from a 20A 12V transformer I acquired years ago.
If I get froggy, a micro controller might be introduced to provide active monitoring and control.
The pictures I had hosted in this thread have vanished. I will look for them and re-post so some of the replies make more sense.
